cut radiator straps? (1 more post to go too)
I put this new 4 core in a few weeks ago - can't tell if I should leave the bands on it or cut them? They LOOK like steel banding on stuff that gets palleted. Do I cut 'em or do they need to stay on?
"A cat will almost always blink when hit between the eyes with a ball peen hammer" (you don't always have to state the obvious) Wear your PPE! You can eat with false teeth but you can't see with a false eye. 1959 Studebaker Silverhawk 350/400 1972 C10 L6 3OTT 2005 F350 - Built - whew! |
Hellasick
![]() Join Date: Jul 2006
Re: cut radiator straps? (1 more post to go too)
I cut mine, since they are steel they will rust off at some point.
I keep two MAGNUMS in my desk. One's a gun, and I keep it loaded. The other's a bottle and it keeps ME loaded. I'm Tracer Bullet. (Calvin and Hobbes) This life was a test. It was only a test. If this had been an actual life, you would have received instructions on where to go and what to do. RED meat is not bad for you...FUZZY BLUE/GREEN MEAT is bad for you!!!!!!!!!!!!! BUILT FORD TOUGH WITH CHEVY STUFF--sticker at Goodguys |
member #16
![]() Join Date: Dec 1999
I took mine off. Figured they were shipping straps.
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors ![]() http://www.flickr.com/photos/1745471...7602865984234/ |
you can keep them or cut but if you leave em then under there will be perfect
I left mine on .
Cruzin
i left mine on i have had rad. shop install them on some of my older rad. i have had worked on
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8 Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U Proverbs 3:5,6 "Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt In memory of our first baby daughter, daddy and mommy love you. Danica Grace 6/26/14
Sisyphus was my mentor!
![]() Join Date: Sep 2002
I had a plymouth that one of those straps rusted at the top & then flapped back and fourth off of the fan & the rad itself. Caused a bizzare sound & a hole in the rad very soon after.
passthebuck ![]() #5642 -TWO 1967 GMC 910's. One with L6/3-on-the tree and the other with 355 w/435hp & a 700r4. -a 2013 Honda Civic as my "sensible" car |
#8 | |
Cruzin
its all about the +6 inches
those bands were used in the process of building the core, it is not needed and the above is a good reason to chop them off.
And afterr reading that story, I now need to cut those straps off the core in my burb. |
and mine will be coming off too! Thanks all.
i actually just bought a brand new rad, and the guy at the shop told me that i should cut them off befor i install it, just so that things like the above mentioned wouldnt happen, so i did i cut them off yesterday
[B][COLOR="Navy"]BUTTERS 72 Chevy longbed C-10 72 Chevy 4x4 Longbed |
#13 |
I was told that you need them. It possibly will warp and crack from heating and cooling. the straps are intended to keep the top and bottom of the core from coming apart. Cut mine before i heard this though.....oh well
1972 GMC G15 shorty van 350cid 1972 GMC K2500 custom sm465 2005 GMC seirra 1500 4.8 |
