Old 01-09-2011, 07:16 PM   #1
gopokes
gopokes's Avatar
Question about guages
I am kicking around the idea of using a gauge cluster from an 02 Camaro in my truck. I want to get my truck back on the road as soon as possible, but I can't afford a new set of aftermarket gauges right now. I was thinking about cutting my original gauge panel and fiberglassing the Camaro gauges in. I'm not sure how it will end up looking, but if I can make it work for a while that would be great. I have a line on getting some of the gauges cheap. The main question I have is if they would even work. Would they be able to read the signals my computer sends out? Here is a pic of the type of gauges I'm talking about.
My build thread - http://67-72chevytrucks.com/vboard/s...d.php?t=391224
gopokes is offline   Reply With Quote
Old 01-09-2011, 08:21 PM   #2
67C10BUB
67C10BUB's Avatar
Re: Question about guages
I would be willing to bet that it would. I put an LT1 5.7L from a Corvette in my 1994 S-10 truck and I used the factory S-10 gauges. The signals from the Corvette ECM displayed all of the correct values on the S10 gauges. I was concerned at the time as well, but it worked great. I don't think GM changes the values much between models/years.
67 5.3L Build
67C10BUB is offline   Reply With Quote
Old 01-09-2011, 09:07 PM   #3
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
I would think as long as your keeping it efi with the PCM you'd be fine.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 01-09-2011, 09:14 PM   #4
gopokes
gopokes's Avatar
Sweet, thanks guys! I guess I will try it and see how it goes.
Old 01-09-2011, 09:55 PM   #5
clinebarger
Dont use a V6 cluster like the one pictured, V8 clusters have 155mph speedo. The big snag I see is the gas gauge that has a serial data feed from the PCM, Unless your running a 98-02 F-body tank & sender the gas gauge wont work.
clinebarger is offline   Reply With Quote
Old 01-09-2011, 10:23 PM   #6
68GMCCustom
good point.
Kurt -
Old 01-09-2011, 10:35 PM   #7
gopokes
gopokes's Avatar
I didn't even notice the pic was from a V6, the one I am getting is from a 02 Z28. I am actually using a gas tank from from a 99 Camaro, so hopefully it will all work out together.
