01-09-2011, 09:06 PM | #1 |
LT1/4 hard starting need help
I swapped a 96 Vette LT4 back in Nov in my 69 C10 and it has been running great every day doesn't skip a beat, except lately it has been a little hard to start. It will start and run most times but when it won't it will pop at the engine (sounds like a back fire),but not out the exhaust and may be enough to blow off a vacuum cap and than crank for bit then start and run great. The next start fires right the odd time it will pop and crank awhile than start. I checked for codes and it has 2 P0135 and P1133. Do I need to change one of the O2 sensor? Not sure what is wrong.
Does anyone have some advice on what I should be checking and or replacing? Thanks Dave Last edited by dave69; 01-09-2011 at 09:47 PM. |
01-09-2011, 09:58 PM | #2 |
born to lose
Re: LT1/4 hard starting
those are misfire codes and it sounds like a fuel issue maybe the pump
Posted via Mobile Device Posted via Mobile Device
_____________________ '67 Chevy Belair Wagon 283 Powerglide '68 Chevy II Nova 2 door 350 TH400 Sold!! '71 Chevy C20 350 TH350 '71 Chevy C10 Burb 350 TH350 stolen totalled gone.... Burb Build http://67-72chevytrucks.com/vboard/s...d.php?t=475155 Nova Build http://67-72chevytrucks.com/vboard/s...d.php?t=498979 Wagon Build http://67-72chevytrucks.com/vboard/s...d.php?t=543052 Not giving a truck. |
01-09-2011, 10:02 PM | #3 |
Dave I am sure that you remember that a lot of those lt engines have [had] problems with the dist cap not venting properly and having a large buildup [or backup as it were] of mositure and condenstion in the cap. It casues a lagre amount of troubles with the running of the lt series. I know it is some trouble to get that cap off but it may be worht a shot. Sorry I don't know what your codes are but maybe a site like lt1.com or ls1 .com might help. Jim
01-10-2011, 12:56 AM | #4 |
Are those codes to with the O2 sensor? I just put higher octane fuel from 87 to 92. To try that because the knock count is 1600 if I remember right and if I get on it hard it will pin than stop pinning. Thought that is worth a try.
01-10-2011, 07:14 AM | #5 |
maybe read up on the board rules about double posting
