01-10-2011, 01:02 AM | #1 |
Rear axle vent
Finished up the rear springs, shocks, etc. During the job noticed the rear is not vented. (Dana 44) I'm not an expert...far from it...but shouldn't it be vented? Looking at the pic you can see a bolt on top of the right axle tube where the vent should be?
"Once a Chief, always a Chief!" MCPO (ret) 03 2500HD- 'Daily driver' 67 Short Fleet- 'Drivable project!' 11 Malibu LTZ- 'The Wife's ride' |
01-10-2011, 01:36 AM | #2 |
Re: Rear axle vent
I thought I'd be a helpful guy and take some pics of my Dana '60' in my Nova..and the vent attachment...can only find a bolt in the left axle tube...no vent..I guess this must be the spot...pics are not the best but it is the only spot I can find...hopefully someone else will chime in...
01-10-2011, 01:44 AM | #3 | |
Re: Rear axle vent
01-10-2011, 03:22 AM | #4 |
Re: Rear axle vent
On mu 67 there is a threaded tube screwed into the axle and it is machined on the other end and a metal cap can snap on and off fairly easy but its not tight at all so it can breath. It doesn't have a hose at all.
01-10-2011, 07:02 PM | #5 |
Re: Rear axle vent
I will contact Strange and find out what is correct..I am sure the bolt comes out and a barbed nipple/hose deal with a breather up under the chassis will do the job..
01-10-2011, 07:15 PM | #6 |
Re: Rear axle vent
speedway motors has a nice small billet breather for rear axels i've used on a number of 9"rears // just had to tap the hole and it screwed in
01-10-2011, 08:23 PM | #7 |
Firefighter
Re: Rear axle vent
Guys on the D44 axle the breather should be in the differential housing not axle tube, on the front pass side on top of diff.
'72 Chevy SWB 350 Auto '67 GMC LWB 350 4 speed '70 Chevy 4x4 Stepside 350 Auto Yellville, Ar. USA |
01-10-2011, 08:54 PM | #8 |
sharp as a marble
Re: Rear axle vent
Have you removed the " bolt "? It might be a 1/8" pipe plug just waiting for you to install a pipe nipple and a hose to vent your rear end. Hope that did not come out as me being a smart ***. I am not sure of this, but on some factory rear ends this is the case. HEY! what ya got to lose sailor!
" any man can make a rate, but only God can make a boatswains mate" for my dad |
01-11-2011, 06:02 PM | #9 |
Re: Rear axle vent
After a little closer inspection...and looking at the item CDDOWNS mentioned, I find my '60' has this for the vent..learn something everyday..
01-11-2011, 08:52 PM | #10 | |
Re: Rear axle vent
