Old 01-10-2011, 10:32 AM   #1
71Crew
what is this switch?
can someone tell me what this switch is on my throttle assembly?
i included a pic of the spid if it helps. thanks having problems adding pics
71Crew is offline   Reply With Quote
Old 01-10-2011, 10:51 AM   #2
Putter
More Cowbell....
Putter's Avatar
Re: what is this switch?
NOS trigger (teehehehehe). (Sorry, I really don't know but at least this will bump the post back up for ya)
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket
Putter is offline   Reply With Quote
Old 01-10-2011, 10:52 AM   #3
71 super
71 super's Avatar
The kick down switch on a 71-72 turbo 400. In 71 they moved the switch from the carb mounted electric kick down to the pedal mounted kick down- they left them there until the end of the 400 trans. If you will look at your trans there is a spade connector coming out near the left side of the tail shaft (still part of the main trans body). This is the other end of the switch and power is pulled from fuse box.
67 blue step side- bb
68 gold and white swb cst anniversary
68 custom swb hot rod Ls swap
69 swb cst 6 cylinder/ overdrive
69 black/black cst bb swb
70 orange and white cst Canada built truck swb bb
71 black and white super swb bb
71 red and white super swb
72 green and white super swb 4x4
62 nova wagon 400 series Ls swapped
68 Camaro 327/4 speed- 1 owner, original paint
66 Volkswagen bettle
69 auto stick Volkswagen Beetle
71 super is offline   Reply With Quote
Old 01-10-2011, 10:58 AM   #4
tolly4503
opps wrong post.
tolly4503 is offline   Reply With Quote
Old 01-10-2011, 12:38 PM   #5
OhOneWS6
OhOneWS6's Avatar
Originally Posted by 71 super View Post
... If you will look at your trans there is a spade connector coming out near the left side of the tail shaft (still part of the main trans body). This is the other end of the switch and power is pulled from fuse box.
This is assuming the turbo 400 trans has not been swapped for something else.
OhOneWS6 is offline   Reply With Quote
Old 01-10-2011, 07:14 PM   #6
71Crew
thanks guys. it was a th400 but since new has become a th350 4x4
