Old 01-10-2011, 02:49 PM   #1
Navy Mechanic
Navy Mechanic's Avatar
Front lower control arms
Starting the rebuild up front tonite. I've got a mixed bag of components and need to replace my lwr a-arms. Currently have 73-87 spindles and rotors mated to a 71-72 lwr arm (with the newer ball joint. The arms have been modified (shock mount relocated and bump/steering stop removed).
I'm installing ECE 1" drop coils and 2 1/2" drop spindles. Need to know if I can use either 71-72 or 73-?? lower control arms?
Thanks in advance for the assistance!
"Once a Chief, always a Chief!" MCPO (ret)
03 2500HD- 'Daily driver'
67 Short Fleet- 'Drivable project!'
11 Malibu LTZ- 'The Wife's ride'
Navy Mechanic is offline   Reply With Quote
Old 01-10-2011, 02:58 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Front lower control arms
Either.
The 71-72 arms are steel bushed.
The 73-87 arms are rubber bushed.
The lower balljoints are the same.
Keith
Convert to disc brakes.
Old 01-10-2011, 03:08 PM   #3
Navy Mechanic
Either.
So I can use either and the lwr ball joints the same...thanks. Having a hard time locating lwr control arms and needed to know my options. Big help...thanks again.
Old 01-10-2011, 03:28 PM   #4
lolife99
lolife99's Avatar
71-87 lower ball joints for 1/2 ton trucks are the same part number.
The 71-72 uppers are a different part number that the 73-87 uppers.
(67-70 trucks,... both upper and lowers are another number altogether)
Keith
