01-10-2011, 07:23 PM | #1 |
truck swerves right when braking
Hey all,
I know something is stuck, but im not too sure how to go about it with drums all around... any ideas? |
01-10-2011, 07:55 PM | #2 |
Truck and auto performance nut
Re: truck swerves right when braking
Either your left front brake is not engaging properly... or your right front is grabbing to soon.
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
01-10-2011, 08:00 PM | #3 |
okay thanks, so its an adjustment issue? theres no way drums can get stuck like calipers correct?
01-10-2011, 08:19 PM | #4 |
67-72 parts collector,…
Leaky wheel cylinder causing it to grab?
01-10-2011, 08:25 PM | #5 |
could be serveral things. you'll just need to jack it up and pull off the front wheels and the drums to find out whats going on.
01-10-2011, 09:11 PM | #6 |
sharp as a marble
well that tells me that the right brake is working and the left one is lazy.
Pull the wheels and inspect, looking for a leaking wheel cylinder, that might have gotten brake fluid on the shoes ( either side ) If you do not find this, check to see if BOTH sides of each wheel cylinder is extending. Sometimes an old WC can get stuck on one side. You could have a rubber brake hose that is collapsed on the left, or staying on a bit on the right side. IF I WERE YOU I would pull the wheels and inspect, and if I found nothing obvious, I would put it back together and adjust the brakes evenly and try it again. I would next suspect WC's and brake hoses |
01-11-2011, 10:38 AM | #7 |
could be the alignment.
when the front end squats it may be toeing out on one side. or if the rear is lifting a panhard could be pulling the rear end over to one side and cause it to brake steer. |
01-11-2011, 10:44 AM | #8 |
Allengator Outta the Blue (my band - available for hire in the DFW area!) 1980 Chevy SWB Pickup (build thread) 1951 Chevy Sedan Delivery 2004 Chevy Tahoe Z71 2011 Harley Davidson Street Glide 2018 Silverado Z71 Crew Cab |
