Old 01-10-2011, 07:29 PM   #1
cam.man67
cam.man67's Avatar
Heater fuse problem
So here's the problem: Last week the heater switch in my truck went bad. All right, no problem, got it ordered from ECE, delivered today. I put the thing in, got a new fuse (in my haste to take the old one out I blew a fuse when the hot wire connected with the dash) everything works fine. For about a minute. Then the fuse blows again. I know the PO rewired the cig lighter so it pulled off the heater fuse, so I unplug my GPS unit, put another fuse in, and the heater works fine. And then it blows again.
Long story short, I don't know what to think. According to the fuse box, that should be a 10 amp fuse, which is what I put in. I haven't changed the wiring in any way, so I can't figure out what could have possibly changed. Suggestions?
I'm tempted at this point to put a 25 amp fuse in and be done with it. Any reason I shouldn't do that?
Thanks in advance!
'68 Dodge Dart 270, 225, 904, 2.76--"Lucy"
1996 Gmc 1500 Z71, 350, 4l60e, 3.73s
1995 Jeep Wrangler Rio Grande 2.5, AX5, 4.10s
1989 Toyota Pickup 22re, auto, 3.73
cam.man67 is offline   Reply With Quote
Old 01-10-2011, 07:36 PM   #2
butters_72
butters_72's Avatar
Re: Heater fuse problem
well if you put in a fuse bigger than whats called for you risk melting the wires or causing more damage than good, those switches run a relay and your relay could be shorting out, have you checked that? if you do decide to put in a bigger fuse i wouldnt just jump to a 25 right away, you could try a 15 amp safley to see what happeneds
[B][COLOR="Navy"]BUTTERS
72 Chevy longbed C-10
72 Chevy 4x4 Longbed
butters_72 is offline   Reply With Quote
Old 01-11-2011, 07:39 AM   #3
cam.man67
cam.man67's Avatar
Ok, so this relay is inside the switch? It doesn't appear to readily come apart.
Old 01-11-2011, 10:29 AM   #4
hugger6933
What speed is the fuse blowing? Is it on high or any position from low on up? There is a high speed relay that is on the heater box behind the glove box. Have you tried to run a jumper [fused of course] to the fan motor? When I first started to try my fan on my 68, I didn't have anything. I started out with a jumper to the fan motor it sparked then ran fine kinda like it might have been stuckor something. after that it all worked fine for a little while then the swicth stopped. I took it apart and cleaned the contacts all is well now. Jim
hugger6933 is offline   Reply With Quote
Old 01-11-2011, 10:34 AM   #5
cam.man67
cam.man67's Avatar
It's high speed. I took the panel off again this morning and found a short in the high speed wire. Cut off the bad spot, it's good to go. Thanks for the suggestions, everybody!
Old 01-11-2011, 12:48 PM   #6
kwmech
Change the blower motor itself. It's drawing too much current
Old 01-11-2011, 01:08 PM   #7
Wrenchbender Ret
Put a 20 amp. fuse in it. The fuse is going to blow long before any wires get hot. It probably has a replacement motor that pulls more curent then the original.
Wrenchbender Ret is offline   Reply With Quote
