needs more $$$
Saggy Tops...
I don't think it's anyone's preference to have a saggy top
![]() Anyone ever fixed this, or is it not possible? I don't know how ghetto or impropper this is, but I was thinking of drilling a hole and spraying some expanding foam into it to see if it brings it back up...is that an incredibly ridiculous/dangerous idea?
1970 2wd Blazer |
Re: Saggy Tops...
Sorry I cant help, but my tops bowed too. If you try that expanding foam post the results up here.
Re: Saggy Tops...
the expandable foam worked i had a 2wd blazer years ago with a double wall top and we put a stick in there as a brace and pushed against it. It helped alot i rather had to see where i drilled a few holes than a wavy roof.
#4 | |
needs more $$$
Re: Saggy Tops...
Is it bad to totally seal up the top with the foam inside?
1970 2wd Blazer |
Re: Saggy Tops...
I tried popping out the low spots on my top by putting a small brace in between the inner and outer shells but it would put pressure on the inner shell and bow it down, so for now I left it.
Let us know how the foam works.
'71 ![]() "If life was fair you'd be able to afford one of each and a garage large enough to house them all." |
![]() Join Date: Apr 2004
Re: Saggy Tops...
1. Remove top.
2. Never put back on. 3. Problem solved ![]()
'72 2wd blazer, bagged w/ watts link & EDC '72 C10 "Lowered Farm Truck" STOLEN 5-18-11 '66 impala ht |
Future TOTM Winner
Re: Saggy Tops...
I've been curious about the foam also. Sounds like it does work. Should also help with sound deadening I would think.
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces) 72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts 2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver Check it out www.lsdyno.com |
needs more $$$
Re: Saggy Tops...
Haha...I've owned my blazer since July and pulled the top the moment it was in the driveway and hasn't been on since...just sucks not to be able to drive it in the winter. In my neighborhood, I'd look "super mexican" in a topless (which most think is chopped) primered "truck" especially now with the 22's...lol
1970 2wd Blazer |
Re: Saggy Tops...
I agree also, but with two tops laying around it was time to clean one up just in case
"85" Monte Carlo SS "71" K5 (SOLD) "64" Chevelle 1930 Chevy two door rat |
