Old 01-10-2011, 10:40 PM   #1
Blue Heeler
Blue Heeler's Avatar
Tire size for Rally rims
Well guys time to lower the Blue Heeler. Just bought some new 15x8 rally
need to know what tires you guys could recommend on a 4 inch lowering kit.
thank. Steve
Blue Heeler is offline   Reply With Quote
Old 01-10-2011, 10:44 PM   #2
Rich 5150 69
Rich 5150 69's Avatar
Re: Tire size for Rally rims
275/60r 15 , is about all you can get under it without any more mods, might be a little tight on the front, fender might come down on the wheel with a four inch drop.
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 01-10-2011, 11:06 PM   #3
protrash64
Resistance is Futile
protrash64's Avatar
I'd consider the rear end ratio if you're planning on a lot of driving. A taller tire mite help a bit. On my bagged 'burb I ran 295/50/15's and 255/60/15's. With the '66 LB I went with 235/70/15's all around.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 01-10-2011, 11:09 PM   #4
Rich 5150 69
Good point protrash, I`m running 373, just buzzing the motor to death..!
Old 01-10-2011, 11:50 PM   #5
Blue Heeler
Which lowering kit are you running? and are those 15x8 on there? the kit i'm looking at is 4"drop in rear x 3"drop in front does that make sense.
Old 01-11-2011, 02:51 PM   #6
1adam12
1adam12's Avatar
Im running 245 60 r 15 with 15x8 ralleys 4inches in front and 5 inches so far in rear no problems so far
1adam12 is offline   Reply With Quote
Old 01-11-2011, 03:34 PM   #7
jchav62
1962 C-10
jchav62's Avatar
The '65 has a 2/4 drop. Running 15x7's in the front with 245/60's and 15x8's in the rear with 275/60's.
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 01-11-2011, 04:28 PM   #8
Jonboy
Slots go on anything!
I have 255/70's on an 8" rally on my '74. It helps fill the fender well. Mine is a little lower though.
1974 Jimmy- 5.3/4L80e/NP241
Old 01-11-2011, 09:39 PM   #9
Rich 5150 69
3/5 drop, 8x15 rims, 275/60 r 15 all four corners.
Old 01-11-2011, 10:04 PM   #10
Blue Heeler
Thanks for the input so maybe a 15x7 up front?
Old 01-11-2011, 10:13 PM   #11
Rich 5150 69
Are you running power steering,? If your not going any lower than mine 15x8 is fine, lower and I would step down to a 7, only because of the interferance issue while turning into a steep driveway for instance.
Old 01-11-2011, 10:17 PM   #12
Blue Heeler
Oh chit, thats the look i'm trying to get. thanks everyone. its a mind
boggler trying to figure out how to do this with out buying a bunch of stuff
that i'm gonna regret purchasing. thanks and thank:{
Old 01-11-2011, 11:07 PM   #13
protrash64
protrash64's Avatar
Are you sure it's 373?? I thought a 275/60/15 was at least 28'' tall; I considered that size before deciding on the 70's series and narrower tires.
Old 01-11-2011, 11:36 PM   #14
Rich 5150 69
Yes I`m pretty sure it is, going by the numbers that were on the housing some many years ago, I`m into thrd gear (turbo 350 ) standard 2 lane intersection before I even clear it...
Old 01-12-2011, 11:40 AM   #15
Blue Heeler
Yup i'm gonna run power steering just ordered the bracket and got the power
steering pump and gearbox just need to get the hoses. Thanks for the help!!!
Old 01-12-2011, 11:57 AM   #16
kieth
kieth's Avatar
I run the same gears but with a 700r4 25% reduction in rpms look at making the 700r4 your next mod.....Kieth
kieth is offline   Reply With Quote
Old 01-12-2011, 05:13 PM   #17
65Gregg
65Gregg's Avatar
265/70/15 on 15x8 rallye-rear
255/70/15 on 15x7 rallye-front
I have to watch sharp turns and driveways, the fronts rub, 4/5 drop.
65Gregg
Blue long bed
White TBSS
61 Impala
“The two most important days in your life are the day you are born and the day you find out why.” Mark Twain
65Gregg is offline   Reply With Quote
Old 01-12-2011, 10:24 PM   #18
Rich 5150 69
That was the plan in `93 when I first did the make over, well just never got around to it always too many projects in the fire..
Old 01-15-2011, 01:35 AM   #19
Blue Heeler
Anyone got anything lower?
Old 01-15-2011, 10:26 AM   #20
protrash64
protrash64's Avatar
Dont understand?? Lower suspension? My 'burb is bagged and my LB '66 is lowered 4/4. Tire sizes in previous post.
Old 01-15-2011, 10:53 AM   #21
astrochimp
From what I have read here, the disk brake kits move the wheels out, so clearance would be tighter if your running disk too.
David
astrochimp is offline   Reply With Quote
Old 01-15-2011, 12:57 PM   #22
paul63c10
Hey protrash, just wondering how this would help?
paul63c10 is offline   Reply With Quote
Old 01-15-2011, 06:24 PM   #23
62 Longbed
62 Longbed's Avatar
Om my 62 I'm running 15x8's with 305/50R/15's on the rear , 235/60R/15's on the front ... Gonna go to the 275/60R/15's on the rear after these tires wear out ... Good Luck with your choice ....
62 Longbed is offline   Reply With Quote
Old 01-15-2011, 10:05 PM   #24
rustyrodknocker
275 50 15 look like a custom centering job on the rallies. I would not mind going a 1/2 " narrower. but if you change any aspect on these metric tires everything is changed. I do not understand how it is better than dimension tall x dimension wide x rim diameter. thats like everything there is to know about tire size in a few simple numbers. or we can resort to the algebra [widthXaspectx2] /2550+rim diameter. for the height and w/25.50 for the width. for those that prefer the hard way. stupid. I found an online calculator a few years ago that would give you the rpm and effective gear ratio with a given size tire. my 275/60/15 with 3.50 came out to the equevalent of 4.10 with stock tire diameter. not terrible but not 75mph either. especially with flowmasters. those had to go.
rustyrodknocker is offline   Reply With Quote
Old 01-15-2011, 10:24 PM   #25
Blue Heeler
Nice truck!!! thanks for the pictures. i guess after a few beers i will choose
a tire that fit under there, it's kinda tuff trying to deside.
