Old 01-11-2011, 12:35 AM   #1
dtkarst
Will it work?
Ive had this question floating around for awhile. I have a parts 63 C10 4 wheel drive longbed sitting in my barn, and a 2 wheel drive 66 C10 shortbed stepside that I am wanting to redo. But is it possible to switch everything from underneath the 4 wheel drive over to my 2 wheel drive? Or am I crazy?! Someone please help me answer this question! haha
dtkarst is offline   Reply With Quote
Old 01-11-2011, 02:39 PM   #2
msgross
msgross's Avatar
Re: Will it work?
can the bodies be swapped easier?
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 01-11-2011, 03:37 PM   #3
dtkarst
Re: Will it work?
Probably but im wanting a 4 wheel drive shortbed. and didnt know if the 4 wheel drive stuff could be switched to a 2 wheel drive frame
Old 01-11-2011, 11:28 PM   #4
msgross
msgross's Avatar
Re: Will it work?
all of the 4 wheel drive parts will be older though (drum brakes, old transfer case etc...)
you would be better off to find a newer 4WD donor... 72 and newer
The Garage:
Old 01-11-2011, 11:38 PM   #5
'63GENIII
'63GENIII's Avatar
Re: Will it work?
I personaly like the LB's myself but if it were mine to swap, I'd probably start looking at shortening that LB frame to used the SB bed. Might be a little involved but way less work than swapping the 4wd stuff over. IMO
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 01-12-2011, 03:54 AM   #6
1malo68
1malo68's Avatar
Re: Will it work?
I don't know if this will help you, but here it is anyway. http://www.chuckschevytruckpages.com/framespecs.html
Dan
1malo68 is offline   Reply With Quote
Old 01-12-2011, 03:19 PM   #7
dtkarst
Re: Will it work?
If i can find a 63 short bed id just swap it over. Theres no one around here that is trust worthy enough to cut the frame for me. So cutting it is out of the question.
