Old 05-13-2001, 01:15 PM   #1
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Cool TPI vs Carb Torque - Vote for your favorite (pics)
Hey gang,
I just added two new pages to my truck's web site. One web of interest for the performance section is this one.
http://www.geocities.com/abetterchem.../tpivscarb.htm
TPI vs Carb torque - which is would be more fun?? Only one of the components will make the installation. The loser will go on E-bay!! What is your vote?
What is the application? http://www.geocities.com/abetterchem...recentpics.htm
http://www.geocities.com/abetterchemist/
And the winner is ............
Gerardo
1983 Custom Truck
TX Plates: "BAD BOW"
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 05-13-2001, 04:33 PM   #2
69Custom
69Custom's Avatar
Post
let us know what you pick.
New Project
  • 72 Blazer 4WD 307/3 spd, PS, PB, Posi (Current Project)
  • 83 Chevy SWB Rebuit 350/TH-350 with shift kit, buckets (daily driver)
http://members.xoom.com/luc_nt
1972 Chevy C-10 Short Stepside
6Cyl, 3 spd, not opts
(Current Project)
Now a 2004 SSR 5.3L with 4L60E
Now Ididit tilt- ps, pb
2002 Saturn L200
2006 Toyota Highlander HYBRID
69Custom is offline   Reply With Quote
Old 03-13-2002, 05:39 PM   #3
kickinbigblock468
Post
TPI definatly... I drove an I-ROC with a 350 TPI and the thing was nuts... I couldnt help but boil the tires. So my vote would most definatly be TPI
1981 Chevy Silverado
468 cid big block
Edelbrock Tunnel Ram Dual Quad Intake (2 600cfm edelbrock)
11.5:1 compression
Comp roller cam and lifters
Comp cams roller rockers
Steel Manley connecting rods
MSD-10 ignition with Pro Billet distributor
Pete Jackson gear drive timing gears
Saveing for a set of Alluminum heads and an 8-71 Blower
468 cid big block
11.5:1 compression
kickinbigblock468 is offline   Reply With Quote
Old 03-13-2002, 06:28 PM   #4
low 84
low 84's Avatar
Red face
I say go with the tpi because you'll be the only one that has it and it looks bad a$$.
But the real reason i say tpi is i want to buy the airgap intake from you - hahaha
Seriously how much you want for it if you decide to use the tpi? if i can get a little money saved up we could do it at the swap meet if your coming, and have made up your mind by then.
Pot holes are my enemy
'84 1\2 ton swb, 350 5\7 drop
just sold '64 1\2 ton
4\4 drop with built 350 (my toy)
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works
'05 1500 Crew Cab
RIP
'84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker
'80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's
low 84 is offline   Reply With Quote
Old 03-14-2002, 07:18 AM   #5
gchemist
gchemist's Avatar
Talking
low 84, Darn you must have alot of free time. This post is really old. I sold the TPI. I'm keeping the Air Gap Intake to use until I go FI. Not sure when but it will be a very long time.
Gerardo
1983 Custom Truck
Old 03-14-2002, 05:08 PM   #6
low 84
low 84's Avatar
Post
i didn't realize this post was so old.
i think kickinbigblock is the one who dug it up out of the archives
'05 1500 Crew Cab
RIP
