Old 01-11-2011, 01:36 PM   #1
TheSeeker
Lost oil pressure!
I was getting my truck ready last weekend to drive to work on monday and doing some repairs/cleaning. I removed the AC compressor which was bad and changed to a brand new water pump. I removed all the ac brackets as well. The temp gauge is busted and most of the other gauges are off, but now my truck starts and idles nice but has no oil pressure. I changed the oil about 2 weeks ago and checked it its nice and full but theres still no pressure. I can get on the free way and the needle just bounces between 0-20. Do you think somethings wrong or the gauge is bad? Any signs to look for?
TheSeeker is offline   Reply With Quote
Old 01-11-2011, 01:43 PM   #2
dan76
Re: Lost oil pressure!
For a quick check, install a mechanical gauge. You don't have to make this a permanent install, just attach the fitting to the back of the block where the sender is. Most likely the sender is faulty. What type of engine/year?
dan76 is offline   Reply With Quote
Old 01-11-2011, 02:00 PM   #3
rusty baker
'70 C-10 Primer
rusty baker's Avatar
If you drove it on the freeway with no oil pressure, it wouldn't still be running.
"The difference between stupidity and genius
is that genius has its limits." Albert Einstein
rusty baker is offline   Reply With Quote
Old 01-11-2011, 02:09 PM   #4
cdowns
cdowns's Avatar
no sending units on these trucks they are mechanical oil gauges from the factory
Old 01-11-2011, 02:40 PM   #5
TheSeeker
So, I should probably get around to replacing the gauges then. I have driven it since sunday on the freeway everyday between 30 and 50 miles round trip. It still starts and idles nice but the gauge reading freaks me out. Stock 70 350 btw. Thanks for the help. If anyone else has any suggestions let me know
Old 01-11-2011, 02:52 PM   #6
allengator
allengator's Avatar
If you really had no oil pressure at idle, it wouldnt take long for the top end to start chattering!
And I agree that it wouldnt have lasted on the highway
Allengator
Outta the Blue
(my band - available for hire in the DFW area!)
1980 Chevy SWB Pickup (build thread)
1951 Chevy Sedan Delivery
2004 Chevy Tahoe Z71
2011 Harley Davidson Street Glide
2018 Silverado Z71 Crew Cab
allengator is offline   Reply With Quote
Old 01-11-2011, 03:14 PM   #7
cdowns
cdowns's Avatar
i'd go to local autoparts and see if they have a cheap mechanical gauge and just disconnect the original and hookup the new one to see if original gauge went bad
Old 01-11-2011, 03:33 PM   #8
TheSeeker
Ok, I havent heard any knocking or rattling either so Im going to pick up a cheap gauge tonight. See if it fixes the problem
Old 01-11-2011, 04:12 PM   #9
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
Maybe a line got kinked when you were working on it? I know it's not really near where you were working on, but it's just kinda weird for it to stop working all of a sudden.
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
