Old 01-11-2011, 04:23 PM   #1
Section8
1972 C10 Brakes
Hey Guys,
Replacing the steel lines on the rear axle along with all the drum brake components The fittings that go to the wheel cylinders are 3/8 but the fitting that connects to the junction of the new brake hose from the frame is not but appears to be 7/16 Is this correct or just a typical issue with all these Chinese replacement parts from NAPA? Thanks.
Section8 is offline   Reply With Quote
Old 01-11-2011, 05:28 PM   #2
67chevy1series
67chevy1series's Avatar
Re: 1972 C10 Brakes
i need to do this as well so any help you guys girls give will help two people
67chevy1series is offline   Reply With Quote
Old 01-11-2011, 08:33 PM   #3
JimKshortstep4x4
Re: 1972 C10 Brakes
I have run into this before and I installed fittings that reduced them down to the right size. Most parts places will have the brake line reducers.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 01-12-2011, 12:22 AM   #4
murry11
Re: 1972 C10 Brakes
You can order replacement lines from Rightstuff detailing or LMC truck.
murry11 is offline   Reply With Quote
