Old 01-11-2011, 05:55 PM   #1
junksaver
68 4x4 Front Axle Junk or Not?
I have the factory original dana 44 drum brake closed knuckle front axle that came out of my 68 1/2 ton. I need to clean up my shop. Is this axle or any parts off it worth anything or should I just scrap it?
68 4wd Stepside
69 2wd Stepside Project
71 2wd Blazer Project
72 2wd 3/4 Ton Project or Parts?
73 4wd Blazer
junksaver is offline   Reply With Quote
Old 01-11-2011, 06:48 PM   #2
BLAZERMAN
Currently Blazerless
BLAZERMAN's Avatar
Re: 68 4x4 Front Axle Junk or Not?
If the brake drums, backing plates and hardware are good you might hang on to them...theses parts are hard to
find new and the purists that want to keep there truck stock could benefit from them.
There may be someone out there that would want the whole axle....not thats its a bad axle its just that the open knuckle disc brake version of the same axle work so much better!
1972 C/30 133" W.B. C&C
1970 GMC 3500 157" W.B. single wheel C&C
BLAZERMAN is offline   Reply With Quote
Old 01-12-2011, 12:23 PM   #3
junksaver
Thanks for the reply. I would hang on to the whole axle, but I need to clean up. I guess I can pull those parts off.
68 4wd Stepside
73 4wd Blazer
Old 01-12-2011, 11:35 PM   #4
68chevyfuelie
68chevyfuelie's Avatar
If it has 4.56 or 4.10 gears in it, I'd possibly be interested in the gears/carrier. Thanks.
68chevyfuelie is offline   Reply With Quote
Old 01-12-2011, 11:39 PM   #5
dutchmanz
Knuckle Buster, Instructor
dutchmanz's Avatar
Dang, you're in driving distance. I needed a steering knuckle just a few weeks ago, but swapped to a newer 10 bolt. I'd say don't scrap it.
Current classic fleet:
72 K5 Blazer CST, unrestored factory Orange paint...mostly
69 C10 factory SWB, 454, TH400, Saddle tan, Rust-o-ration
53 Studebaker M35 w/331 Reo gas I-6, Air Force Strata Blue
dutchmanz is offline   Reply With Quote
Old 01-15-2011, 03:44 AM   #6
Americanrider
D-44 carrier is the same old or new, they are all 30 spline. I got 45 bucks out of one a long time ago.
Americanrider is offline   Reply With Quote
