Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Welcome and Discussion > General Discussion
Old 01-11-2011, 10:29 PM   #1
darkone
Its a Nissan; But this is my home: z24 8 spark Power loss & engine shut off
I took a short trip yesterday in my 1984 nissan with a z24 8 plug engine to get some sand for my 70 chev.
what i noticed early in the trip:
slight lurching
minor flickering of the dash lights
reluctance to reach freeway speeds
what i noticed on the return trip:
extreme bogging down.
inability to make it up any hill without excessive clutch engage/disengage.
simultaneous headlight/dash/engine shutdown (everything but breaks was powerless)
key in start position after pulling over on shutdown; magically power came back within 1-3mins
i started it drove about 100yds and complete shutdown again.
once again magically power returned after about 3-5 mins
engine was bogging down more than ever
what i have done:
replaced the battery
cleaned all terminals
cleaned all wires
any guesses would be much appreciated. i talked to a auto electric guy today and he said to check out my fuses. anyone have any other guesses?
darkone is offline   Reply With Quote
Old 01-11-2011, 11:09 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Its a Nissan; But this is my home: z24 8 spark Power loss & engine shut off
Sounds more like an overheated Circuit breaker that is re-setting itself to me... But I wouldn't have a clue where.
LockDoc
Leon
Old 01-12-2011, 03:05 AM   #3
geezer#99
geezer#99's Avatar
Sounds like a bad ground. I had a similiar prob on a 1990 chevy blazer. was a loose ground under the dash. Check all your grounds.
geezer#99 is online now   Reply With Quote
Old 01-12-2011, 02:07 PM   #4
screwballl
Tonawanda 454
screwballl's Avatar
I ran into something similar although yours sounds like it may be a combination of a few things.
First, try replacing the ICM (Ignition Control Module) in the distributor. The one for my 91 burb when I had it was cheap (around $10) but I am not sure of pricing for your Nissan. When mine went bad, it would work fine, then slowly lose power until the engine just died. Once it cooled off enough, it would allow it to start, drive for a mile or two then cut back and die again.
I ran it for a bit after I got the part until it died, then popped off the distributor and there was a little smoke coming off mine so it was definitely overheating.
This may be just the first step but definitely worth looking into.
91 Chevy Suburban Tonawanda 454 R2500 - SOLD!!!
04 Dodge Durango 5.7L Hemi 2WD, 24K miles (as of July 2011)
In the past 30 years about 90% of Fords are still on the road, the other 10% made it home.
screwballl is offline   Reply With Quote
Old 01-12-2011, 02:26 PM   #5
darkone
just wanted to say thanks to everyone for the help! I've gotten some very good info here so far. hopefully ill get her figured out today!
Old 01-12-2011, 03:45 PM   #6
GmtGmt
Conversion Truck Addicted
GmtGmt's Avatar
bad ground
Thomas
Tonight mine pulled a few cars out of snowbanks, and is sitting in my driveway, icicles on the grille, wheels just white cakes of snow, buried up to the lug nuts in powder, straps and chains wrapped around the bumpers, the outline of the wipers clear in 4 inches of snow on the windshield... A tired warrior of the 1980s in a world of low profile tires, front wheel drive, and plastic bumpers, where people stay in their houses until snowplows move the offending substance from their paths, too helpless to travel without AAA and chains and salt, clearing their windows with longhandled brushes while gently stepping around in the snow trying to stay nice and dry.
GmtGmt is offline   Reply With Quote
Old 01-14-2011, 01:02 AM   #7
darkone
could driving on a plugged fuel filter for nearly 30 mins over load one of the systems or cause shutdown somehow?
