01-11-2011, 10:37 PM | #1 |
urthane bushings
I would like to replace my front bushings in my a arms.How do i get them apart, Remove the the rubber bushings?
01-11-2011, 10:47 PM | #2 |
Re: urthane bushings
un bolt them
my sports car rolls on six wheels only because I'm to fat to get in and out of new corvette http://hubgarage.s3.amazonaws.com/ph...ped_detail.JPG |
01-11-2011, 10:50 PM | #3 |
do you have the arms off? I just did mine last week. I used a propane torch and set the bushings on fire. I let them burn for about 10 minutes and all the rubber pushed out. I was then able to slide the shafts off the arms. once the rubber was out of the way I just used an air hammer and pushed out the sleeves. eberything came apart real easy, just made a smokey mess! I will take them took work and have the new bushings pressed in. I am sure there are better ways but i was just making do with what I had.
01-11-2011, 10:57 PM | #4 |
Yes, I have the assembly off the truck and have been trying to take them apart.
01-11-2011, 11:03 PM | #5 |
worked pretty good for me, maybe took 15-20 minutes per arm.
01-11-2011, 11:22 PM | #6 |
If you are putting urethane bushings in you will need to reuse the metal sleeve.
The torch method works great for getting the rubber out. Posted via Mobile Device
CHEVY ONLY |
01-11-2011, 11:36 PM | #7 |
Slots go on anything!
You can also drill holes in the rubber and pull the pieces out, too.
1974 Jimmy- 5.3/4L80e/NP241 |
01-11-2011, 11:41 PM | #8 | |
That's cool Releases the tension holding the rubber in? Good info Jon Posted via Mobile Device
CHEVY ONLY |
01-12-2011, 12:42 AM | #9 |
good luck wwith them. I put the WHOLE complete set, Body Bushings and all. Man that really stiffened things up. I dont think I would do it to a truck again. Mine was an 85 LWB
2004 Silverado Crewcab (Dark Spiral Gray) |
01-12-2011, 02:30 AM | #10 |
Home Built '87
There are several threads talking about this....try look in the suspension category.
or- Post #39 http://67-72chevytrucks.com/vboard/s...=424833&page=2
Gordon 1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424 1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833 Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969 |
01-12-2011, 07:13 AM | #11 |
My energy suspension poly urethane bushings came with the sleeves...
Posted via Mobile Device |
01-12-2011, 07:59 AM | #12 | |
Watch out for your cornhole !
Mine too. I vow to never in my life run another urethane control arm bushing. No matter how much of that expensive grease I smeared on them they creaked like the bed in a honeymoon suite at a 10 dollar motel.
01-12-2011, 09:26 PM | #13 |
OutOfMyMind & I'llNeverKnowWhy
I've run black ones for years and never have to grease them. Then I got a set of red ones and they make tons of noise. Supposedly the black ones have graphite in them to make them quite. I dont know if they do, but they seem to not make noise like the reds.
-Justin-Out of my mind and I'll never know why 1976 Chevrolet Silverado C10 350 4bbl / TH350 Big10 longbed 1986 Pontiac Firebird T-Top 5.0L TPI 700R4 WS6 1992 Pontiac Firebird T-Top 5.0L TBI 700R4 My cardomain page I don't like to save, it's more fun to spend!! |
01-13-2011, 03:22 PM | #14 |
I always take them to a shop to have pressed out and new ones pressed in. I did a set once and from then on have taken them somewhere. I also have the lower ball joint pressed in and the upper ball joint cut out at the same time. They charge $75 to $100 around here and it's well worth it.
