01-12-2011, 12:08 AM | #1 |
3/4-ton LWB to 1/2-ton SWB- Shorten or Swap?
The last time I did this 10 years ago I happened to have both a long bed with a nice cab and a short bed with a junk cab and rebuilt chassis. Now I have a 3/4-ton long bed with leafs in the rear and wonder should I shorten this frame and add trailing arms? Keep the leafs and flip the rearend? Or swap to a short bed frame? Can you just add 1/2-ton spindles and brakes to the 3/4 ton or are the control arms different? Trying to go the simplest route since the truck is together and running. When I swapped before neither had any running gear and the short bed frame had already been gone through with a drop kit and disc brakes added- it was a no brainer just to swap. Thanks Jim
01-12-2011, 09:27 AM | #2 |
Re: 3/4-ton LWB to 1/2-ton SWB- Shorten or Swap?
The last one I did I back-1/2'd the 3/4t frame and fabbed a 4-link. That was a pro-street build but would be a way to go for a cruiser,too. Finding a short frame would sure make it simple. By the time you get the trailing arm stuff and swap it after shortening you'll have a chunk of work. Probably lowering with springs would be the simplest. Lots of options/combinations...flip,longer shackles,drop spring mounts,drop leaves.
01-12-2011, 09:46 AM | #3 | |
67-72 parts collector,…
The 3/4 ton lower a-arms have a bigger ball joint hole. Either find some 1/2 ton lower a-arms or buy ECE's conversion drop sprindles. (they allow you to install 1/2 ton rotors and calipers,... without changing anything) I would try to locate a swb coil spring frame.
