Old 01-12-2011, 02:48 AM   #1
hotrod1
56 - autocross
hotrod1's Avatar
Welding grade 8 nuts
I want to weld nuts into my frame before I finish boxing up the frame. If I weld a nut to the frame will it change the strength of the nut? How is this usually done?
hotrod1 is offline   Reply With Quote
Old 01-12-2011, 03:08 AM   #2
Mike Bradbury
Mike Bradbury's Avatar
Re: Welding grade 8 nuts
Yes it will change the strength of the nut. It will anneal the temper, where it ends up depends on your welds Generally when you weld a nut on the inside of something it only needs to be tacked to hold it in place while there is no bolt in it. It should maintain a fair amount of strength with small tacks. If you weld all the way around then you might as well just get a gr 2 or 5.
I'd rather attempt something great and fail.. than try something ordinary and succeed. Norman Vincent Peale
Project: Barn Raising http://67-72chevytrucks.com/vboard/s...d.php?t=414961
Project: 30 Be Low https://67-72chevytrucks.com/vboard/...d.php?t=830583
Mike Bradbury is offline   Reply With Quote
Old 01-12-2011, 03:10 AM   #3
hotrodrookie
hotrodrookie's Avatar
Im about to do the same thing, Im going to use lower grade nuts that arent heat treated because I know for a fact grade 8's are heat treated, thus welding will change the metalurgy and probably make them brittle(how much I dont know) Maybe someone else can chime in with more info on this.
hotrodrookie is offline   Reply With Quote
Old 01-12-2011, 03:30 AM   #4
Tchia65
I amount they loose is completely dependent on the amount of time they are exposed to the arc so there is no diffinative answer. I the question is does the item really require grade 8 strength? If not don't worry about it. You could always bump up the grip size of the bolt to compensate for the loss of hardness, say go 1/2 or 7/16 instead of 3/8. I'm also a big fan of these. They have a weldable flange. http://www.mcmaster.com/?orderview=n...d-nuts/=ajyb2h
1958 Fleetside shortbox
1965 Malibu SS
1970 Camaro RS
1972 Malibu wagon
Tchia65 is offline   Reply With Quote
Old 01-12-2011, 05:23 AM   #5
Roddude
Roddude's Avatar
How about using caged nuts.
Roddude is offline   Reply With Quote
Old 01-12-2011, 06:31 AM   #6
S10Fan
Old Heap Driver
That's the way to go, I've purchased those locally at Fastenal and a Mom&Pop type operation.
_____________________________
Bryan
'99 Silverado 1500, 4.3, 5-speed, reg cab, short bed
'50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser.
'40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver.
S10Fan is offline   Reply With Quote
Old 01-12-2011, 03:32 PM   #7
Roddude
Roddude's Avatar
I was thinking of these. Please forgive the referance to the other brand of truck!
http://www.classictrucks.com/tech/09...ig_welded.html
Old 01-12-2011, 07:04 PM   #8
Tchia65
Those will work, but if you don't need the floating nut for aglinment issues then it's kind of over kill. I use those for door hinges and and raised bed mounts.
1965 Malibu SS
1970 Camaro RS
1972 Malibu wagon
