Pictures of our Trucks with Modern Wheels?
I was wondering what out trucks '67-72' would look like with the new Factory wheels? Any pictures? Thanks!
![]() Last edited by FLDBRED; 01-12-2011 at 03:12 PM. |
its all about the +6 inches
Re: Pictures of our Trucks with Modern Wheels?
they generally don't fit. Some exceptions, but even those ones don't quite look right
On most of the newer factory wheels the offsets are wrong. They can be spaced out. But as longhorn said they never do look quite right.
--------------------------------------------------------------- Jason. 68’ GMC shortbox https://67-72chevytrucks.com/vboard/...d.php?t=794201 72' 2WD Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=425385 67' LongBox C-10 http://67-72chevytrucks.com/vboard/s...d.php?t=691845 InstaGram ybnorml67 |
gets board easy.......
the only wheel i have likes were the 90's 454 SS wheels, or the impalla SS 17's, other than that not a fan
Thanks for the feed back!
![]() Join Date: Jul 2010
I was hoping for some pictures???
Mark 1972 C10 SWB LS1/T56 6 speed trans/4:56 posi with 5.5"-7" static drop/Boss 338 Wheels 18"x20" My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=424609. My first start up http://youtu.be/R899YQ1OcjU |
there's a few, and I honestly hope they get posted... I'm not trying to be a thread crapper. The question comes up about once every week or two, so the interest is there, and I know there's a handfull of 3/4 ton guys with them and more than a few 1/2 ton guys with spacers...
The Niner
![]() Join Date: Nov 2010
more pics....i'v seen some with the impala ss rims that looked ok.
Here are mine, and I agree, the offset just aint quite right, but they were "free" so whatever. what I would like to do is put the hummer wheels off my diesel on it when the tires are more worn out. the backspace is better.
I also want to see 02 and up Dodge 2500 17"'s on one of these trucks. think they would look nice is a retro-mod kind of way
1971 C-20 350/350 |
i would like to see a set of these on one but im pretty sure the offset is wrong on them.
#13 |
![]() Join Date: Dec 2007
Tried some on my 68 from my 07 burb. No dice, as far as strickly bolt em on goes. Hub center diameter is different. Could be done though I suppose......
#14 | |
i would like to see these on one of our trucks. |
#15 |
![]() Join Date: Apr 2000
Here is mine with 2000 Tahoe Wheels. Its the only pic I have.
1970 CST/10 402,700R4,3:73 posi,AC,PS,PB,TLT,PW,Buckets with heaters |
#16 |
Now were talking! Did you have to use spacers or anything?
#17 |
DZNUCKS, i would like to see those on one of our trucks, also
#18 |
those 20 Tahoe wheels are nice, its about time Gm started making decent looing wheels.
I wish they would put some bigger wheels on their duallys |
#19 | |
Charlie Daniels w/ a Tq Wrench
The Dodge 2500 17s will sit further in than your 16" GM PYO's, they have about an inch more backspacing than your PYO's.
ΜΟΛΩΝ ΛΑΒΕ 67 C10 Shortbed "Great Grandpa's Truck" I6 3 on the Tree 71k original miles 5.3 swap in the works69 K5 Blazer-Family Beach Cruiser Project 78 K30 Dually Semi-Retired Fire Truck 350/SM465 35"s SOLD01 2500HD ECSB 6.0 4x4 5.13's 8" lift 38"s Last edited by GCncsuHD; 01-13-2011 at 12:19 PM. |
#20 |
No spacers and no rubbing. They are 16X7 5on5. They were on the 2000 Tahoe Limited only. 1 year - 1 model. Im running 265x70x16 its almost a 31x10.5x16
#21 |
Junior Member
I have the front center caps on now. I just need to get some dually center caps for the rear or run a a spacer.
71 Suburban 350/700R4 Project Trixie 72 CHEVY,Highlander,SWB,396,T400 Last edited by BB72CHEVKT; 01-13-2011 at 02:42 PM. |
#22 |
i want to see one with chevy SSR rims, 18's front and 20's rear
#23 |
Old member
Are these the new Camaro wheels?
I would like to find a set to try if so. ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
#24 |
Will the rims off a 2004 chevy 1500 SS fit? or is it the same offset problem
#25 |
The only issue with the new comaro rims is the bolt pattern is 5x4.75, which is not a common truck bolt pattern.
You would have to convert the front spindles and rear axles. Surely that can be done, but I am not for sure. Anybody got any insight on this? |
