floorpan/rocker gap!
P.O Didn’t complete the job as usual! I have this gap on both sides of my floor pan. Any recommendations on how to fix this problem?
Thanks, Andrew |
Re: floorpan/rocker gap!
Looked at any other trucks like yours to compare?
I think this is the second thread this week about where the floor pan steps down to meet the rocker at the door seal flange. Is that where you mean? Not a gap,such as where you see light,right? Maybe I'm not understanding but I believe you are talking about where the door seal goes?
I think the only problem you have is you are missing your door sill plates.
"Some of my finest hours have been spent on my back veranda, smoking hemp and observing as far as my eye can see." - Thomas Jefferson 72 C10 SWB "Work in Progress" |
Special K you are on the right track! The P.O cut out the “step down” form the floor pan. Original floor pans have the entire rocker panel attached. I’m thinking the easiest way is to just weld a flat piece across the entire stretch to connect the floor pan to the rocker,and then put the sill on top.
Andrew |
#16876
The gap I see is for the door seal. Are you referring to the hole next to the dimmer switch? If so you most likely will have some minor kick panel repairs as well. Nothing major though.
Posted via Stationary Device '71 Custom Deluxe C-20 402. '67 Buick Special 455. '49 Plymouth Special Deluxe. "I love that old car smell" ![]() Some people are like Slinkies... not really good for anything, but they still bring a smile to your face when you push them down a flight of stairs. |
The Older Generation
Believe it or not that gap is supposed to be there. Like others have said the door seal rubber fits down in there. Also the fuel gauge and dome light wires run through it... LockDoc
The reason I asked if you looked at any other trucks is because that picture shows the rocker/floor area to look mostly like it should.
there is nothing wrong with your truck, at least in what your picture shows. This I promise you..
no no.. Im pretty sure it supposed to have ducttape with resin over the top of everything... Atleast you didnt have my PO..
66 Gmc 1 ton. Long Step 351e V6 69 1/2 CHEVROLET (now a shortbed) LONGBED! ![]() ![]() 61 Shortbed Fleetside 1/2 ton.. in progress Next a 50-53! MY BUILD THREAD http://67-72chevytrucks.com/vboard/s...d.php?t=447926 |
My PO loved Bondo! Woohoo, cracks everywhere!
Trevor "You already said spite" |
