Old 01-12-2011, 07:13 PM   #1
likaroc13
Rollin' Old Skool
manual vs. power front disc brakes
so, i'm getting closer to a front end rebuild on my '66...i will be converting to front disc brakes during the process...i'm just wondering if i should convert to a power booster/master cylinder for disc or just change to a manual master cylinder for disc...how much of a difference will i notice? it will still have rear drum brakes...and i actually have a '72 parts truck with booster, but i'm not sure if the booster is good....also just for reference, the truck is a 1/2 ton short/fleet with 327/auto...when finished, my plan is to drive it 2-3 times per week
thanks for any info/help/suggestions
Old 01-12-2011, 07:20 PM   #2
k1rodeoboater
Re: manual vs. power front disc brakes
you've got the parts...might as well.
k1rodeoboater is offline   Reply With Quote
Old 01-12-2011, 09:31 PM   #3
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
power is easier, non power looks cleaner on the firewall..
John
1999 Toyota Tacoma 4x4
Old 01-12-2011, 10:18 PM   #4
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
I think he said he wasn't sure the booster was any good.
I think he's asking if he'd be fine with discs up front, but no power.
66 C20 Service Truck:
Old 01-12-2011, 10:22 PM   #5
nachodog2
Hell yeah!!!
nachodog2's Avatar
I used a ' 72 corvette manual disc brake master with proportioning valve out of my donor '73 c10 and it stops surprisingly well. Have not had any problems.
Stock is good but custom is the sh*t!
nachodog2 is offline   Reply With Quote
Old 01-12-2011, 11:15 PM   #6
likaroc13
Rollin' Old Skool
that's correct...i know i've seen some nice trucks on here which look to have manual disc, but i'm looking for feedback on how well they perform without a booster
thanks for the info
Old 01-12-2011, 11:22 PM   #7
k1rodeoboater
oooooh....well yeah in that case you'll be fine w/o the booster.
Though depending on how your WOAH:GO!! ratio you may want the power brakes.
Old 01-12-2011, 11:28 PM   #8
Rich 5150 69
Rich 5150 69's Avatar
If you go full manual, raise your brake pedal rod on the arm if possible, it will give you more pedal force.
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 01-13-2011, 12:10 AM   #9
markeb01
Senior Enthusiast
markeb01's Avatar
After I swapped in the 75 front suspension with disc brakes I ran a manual master cylinder for a year or so. I have missing spinal discs, and over time it got to where I could barely stop the truck it hurt so bad to apply the amount of pressure required with the manual discs up front. I decided it was time for a booster. Once that was in place I've never a problem since. So from the experience of someone with chronic back pain it makes a huge difference having the booster, and I have a somewhat small booster - the 9" single diaphram type from Master Power Brakes. A bigger booster would probably reduce pedal effort even further:
http://www.mpbrakes.com/uploads/prod...1753_large.jpg
Old 01-13-2011, 01:04 AM   #10
'63GENIII
'63GENIII's Avatar
My kid brother and I converted his '64 GTO from drum front to 4 piston Vette caliper disc and those brakes would put you through the window. Of course that could have been because the lawn chairs we were sitting in weren't bolted down yet! Seriously though manual disc did not seem to require more force than manual drums but it stopped WAY better. I remember when he put the booster in and it seemed real touchy to me for a long time. Still stops great and that was done 25 years ago.
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 01-13-2011, 08:42 AM   #11
duallyjams
duallyjams's Avatar
I think Mark hit it right. If you are good and healthy then you will have no problem with manual disc brakes.Power brakes simply make it easier.
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 04-26-2011, 06:53 PM   #12
67chevemall
67chevemall's Avatar
Hey was wondering if the 72 corvette master was a bolt on or did you have to relocate the bolts???
great idea btw
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
Old 04-26-2011, 07:44 PM   #13
lakeroadster
The other thing to keep in mind is the amount of vacuum your engine will make. If you are running a rowdy cam it may not have enough vacuum to actuate the booster.
Just remember the booster doesn't make the brakes function any differently inregards to stopping distance, it only reduces the amount of pedal pressure you have to apply.
The guy that runs this shop is the guru when it comes to braking... and he answers emails too! Click on this link: CH Topping & Co., Performance Brakes
He helped me with the set-up I have on my Ford 1927 Roadster Pickup. It has a manual disc/drum set-up and also uses a 'vette disc / disc master cylinder, like Nachodog referenced above.
lakeroadster is offline   Reply With Quote
Old 04-27-2011, 10:57 AM   #14
67chevemall
Good Stuff....I'm going with the manual one from CPP for $139 with the valve.
Old 04-29-2011, 08:32 AM   #15
duallyjams
duallyjams's Avatar
Well post some pics of before and after and maybe a little wright up about it.
James
IG duallyjams
Old 04-29-2011, 10:28 AM   #16
CVA59
[quote=lakeroadster;4648030]The other thing to keep in mind is the amount of vacuum your engine will make. If you are running a rowdy cam it may not have enough vacuum to actuate the booster.quote]
Yes, Lake is correct. I am running a big mutha thumpr cam in my truck and as a result i HAVE TO run manual brakes. It is my understanding that you need at least 14-15 lbs of vacum to run P/B's as designed. With my cam, my engine is putting out about 2-3 lbs. I don't see any problems running manual over power.
Zack
www.23t.weebly.com
_________________________________
CVA59 is offline   Reply With Quote
Old 04-29-2011, 12:32 PM   #17
67chevemall
This is great to know! I am a less parts less systems kind of guy...
Old 04-29-2011, 01:09 PM   #18
jocko
jocko's Avatar
CVA 59 - 2-3 lbs!! You MUST post an audio clip of that cam... sounds like a mighty loper. Gotta love that sound!
Old 04-29-2011, 07:17 PM   #19
CVA59
LOL, I will get a vid up for sure. I hope to have it running in 3-4 weeks.
Zack
www.23t.weebly.com
Old 04-29-2011, 11:08 PM   #20
Rich 5150 69
[quote=CVA59;4652880]
You can always add a vacuum reserve canister...
Old 06-30-2012, 03:48 PM   #21
LostMy65
LostMy65's Avatar
I'm still fighting power discs on my 66.
I'm going to go get a vett master and see if I can get solid brakes that way.
Old 11-27-2014, 03:04 AM   #22
SierraMtns
SierraMtns's Avatar
Anyone know what the bore size is on the vett master?
SierraMtns is offline   Reply With Quote
Old 11-27-2014, 03:20 AM   #23
NEWFISHER
NEWFISHER's Avatar
67 and up power assist used a 1 1/8 bore and the non power models were a 1" bore.
GOD BLESS AMERICA!
NEWFISHER is offline   Reply With Quote
Old 02-11-2015, 02:04 PM   #24
67chevemall
Well been driving with manual brakes for a while now and no problems at all. No need for all those power parts. IMO
Old 02-11-2015, 02:05 PM   #25
67chevemall
Kids in the back seat may cause accidents, accidents in the back seat may cause kids, so no back seats no accidents.
EPIC! LOL
