Old 01-12-2011, 07:58 PM   #1
brans72
GM serpentine belt system ?
What year 4.3 do you get them from and guessing you take everything correct? Anyone wanna give break down? Thanks
brans72 is offline   Reply With Quote
Old 01-12-2011, 11:04 PM   #2
hugger6933
Re: GM serpentine belt system ?
The 4.3 was put in mid year 88 in the s10. The braket in 88 was a steel one piece and is not the most desirable. In 89 the most common two piece bracket was used in the s series as well as the c-k full sized trucks. That braket remained basicly unchanged untill 96 when the vortec styled motor came out [4 bolt on intake per side]. 96 -99 had a bracket that mounted the alt on pass side a/c on driver side [that backwards from the other stlye] You will also need the water pump and the fan and clutch to keep from overheating as they turn backwards from the v-groove type water pump.If you happen to find a set up that has a smog pump it can be removed as some trucks can from the general without them starting in 90 I think if I remember right.You can change the pressure valve on the back of your pump andnot have to change your pressure line or you can buy an adapter if you want the tighter feel that the newer pump will give. If I have left anything out I'm sorry. If you need more help I will be to and others will chime in to fix my statments if incorrect.Jim
hugger6933 is offline   Reply With Quote
Old 01-12-2011, 11:33 PM   #3
firedog
firedog's Avatar
my serpentine setup is off a 4.3 unknown year i took everything off the front of the motor water pump, alternator, brackets, i then bought the ac compressor delete pulley and the 1 wire adapter for the alternator i do not have the part numbers on either of them but if you do a little searching around on the board you will find the part numbers, also good luck on the belt, that was the worst part of it was finding the right belt i even measured and double checked it still took 3 or 4 tries...
*SOLD*
1968 Chevy SWB Fleet
350/350 combo
Tach/tilt/buddy buckets
Bagged/18" Wheels
Black on Black
Project "Pandemic" the Farm Rat
1927 Chevy Capitol Truck Rat rod
'30 Model A Frame
Dual Carb 5.3 LS
http://www.67-72chevytrucks.com/vboa...d.php?t=804162
2007 GMC 4 DOOR 2WD
BUILT 5.3 STAGE 3 CAM 93 TUNE
LIFTED 22X12 WHEELS 33" TIRES
2023 Jeep RENEGADE
Wifes ride
firedog is offline   Reply With Quote
Old 01-13-2011, 12:24 AM   #4
vasquezmrysvll
"the other guy"
vasquezmrysvll's Avatar
im running a setup from a 88-92 V-8 F-body.
God Said,"Building A 10 Second Import Is Like Coming Out Of The Closet, In The End Ur Still....."EXPLETIVE"
vasquezmrysvll is offline   Reply With Quote
Old 01-13-2011, 12:30 AM   #5
63chevyll
gets board easy.......
63chevyll's Avatar
Why don't you run Chevy truck stuff, mid 90's
63chevyll is offline   Reply With Quote
