![]() Join Date: Feb 2009
Could someone please post pics or a diagram of the correct heater hose routing with factory air-small block
Thanks |
Re: Heater hoses with AC
Here you go, 5/8 hose from intake fitting to the valve and from valve to lower fitting on heater core then 3/4 for the return. Hook it up wrong and you will mix hot air with your A/C, defeating the valves purpose and making the A/C system less efficient.
I'm not a pessimist, I'm just optimistic that bad things are going to happen. 1971 Cheyenne Super K10 - tilt, cruise, air, am/fm, tow hooks, factory buckets! 1986 Jeep J10 pickup, - 5.3L Vortec with 4L60e and NP241. |
Thanks chipflyer-I need to get ahold of you for my new spid soon also!
