Old 01-12-2011, 10:14 PM   #1
solrac8d7
Bad News
I took my truck to a chevy dealership today to get a wheel alignment and the guy said my frame might be bent. So I contacted the man who sold me the truck and asked if it's ever been in a wreck. He said the truck belonged to his brother who purchased it brand new then passed down to him. Should I take it to a body shop to have them check it out and do some measurements?
solrac8d7 is offline   Reply With Quote
Old 01-12-2011, 10:23 PM   #2
pig rig
pig rig's Avatar
Re: Bad News
hell Id get under it with a tap and pull a cross massurement to see if its out of square and then look down the frame rails to see if they have a twist then go from there
my sports car rolls on six wheels only because I'm to fat to get in and out of new corvette
http://hubgarage.s3.amazonaws.com/ph...ped_detail.JPG
pig rig is offline   Reply With Quote
Old 01-12-2011, 10:49 PM   #3
dropd80s
dropd80s's Avatar
Re: Bad News
If the bend is slight and not in a horrible area, getting your frame pulled is not that bad really. Might also try another alignment shop with a little more experience in trucks like yours. I know the first 73-87 I had aligned the bushings were wore enough it couldn't be aligned. Swapped all the bushings and balljoints while I was in there, aligned it, and it drove like a dream.
dropd80s is offline   Reply With Quote
Old 01-12-2011, 11:09 PM   #4
spudz
spudz's Avatar
Re: Bad News
check for worn control arm bushings or even bent control arm.
2004 z71, 96 z71 on 38s, 88 Chevy k5 blazer, 4in lift. 84 swb project, 82 SWB project , 84 chevy 4x4 lwb project, 88 Jimmy beater/highschool ride. 79 c30. 99 tahoe 4x4 project. and a bunch of parts trucks..
spudz is offline   Reply With Quote
Old 01-13-2011, 01:09 AM   #5
85silverbeast
85silverbeast's Avatar
Re: Bad News
"Might" be bent is either bent or not get under there and check for yourself.
85silverbeast is offline   Reply With Quote
Old 01-13-2011, 09:34 AM   #6
solrac8d7
Re: Bad News
Thanks guys for the feedback. I really appreciate it! Ill take some pics when I get home from work to show you.
Old 01-13-2011, 10:14 AM   #7
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: Bad News
Where are you located, there is an independent shop close to me that is a 2nd generation front end/alignment shop, I think they could fix just about anything. it took them about 1hr to remove my entire Front suspension, replace all bushings and etc and put it all back together on my truck, they eye balled the align and when aligned it only took like 15 minutes to put it on the machine set up and align. there are two brothers that own the shop their uncle started about 50 years ago.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 01-13-2011, 11:33 AM   #8
motornut
78K & 79C Jimmys
motornut's Avatar
Re: Bad News
they didn't say where?
I would think/hope if a gm shop tells you that,they should be pointing to it/where/why they couldn't do it
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 01-13-2011, 08:49 PM   #9
solrac8d7
Re: Bad News
What the guy had said was LR had .72 and the RR had -.37 with a total thrust line of .52 He might as well of been talking chinese because I don't know what that means or how to fix it.
Old 01-14-2011, 01:27 AM   #10
datguysaL
Re: Bad News
could be just the front end bushings as mentioned earlier. or your rear axle leaf spring pin is broken or not centered correctly.
and remember the chevy lean, alot of newbie shops wanna say u have frame damage when really u dont.
datguysaL is offline   Reply With Quote
Old 01-14-2011, 10:15 AM   #11
motornut
78K & 79C Jimmys
motornut's Avatar
Re: Bad News
i duno numbers but
the thrust line is the straight wheels,match the body,match the steering
when you drive it does it track straight
what you could see is if the steering wheel is straight and the truck drives straight?
have someone follow you see if it's dogtailed?
means when driving do the front and back tires track the same to keep the truck straight
John
