Old 01-12-2011, 11:46 PM   #1
74chevy3/4
Awwww help im getting mad
ok as my title says im getting mad and thats when you start missing things ...
so here it is about 2 weeks ago i replaced all my plugs, wires, cap, and roter.... ran better then ever soo soo happy. then on New Years Eve a lady backed into my front passenger side in a parking lot =*( "yes i cried"
No major damage slow speed fender bender. damaged front fender bumper brush guard marker lights and bezel. Engine compartment appears unaffected.
Now runs very bad. Misses at idle gets worse with throttle often stalls like someone messed with plug wires (didn't happen). I have checked all plugs wires cap rotter. Got it all and making good connection.
what should i check look at anything. I don't think it has to do anything with the crash but why did it run great then not?
I need to get this running well again its my daily driver please and thank you
74chevy3/4 is offline   Reply With Quote
Old 01-12-2011, 11:53 PM   #2
big_b
Re: Awwww help im getting mad
check your vacuum lines. recheck your plug wires with a multi meter, maybe there is a bad connection.
big_b is offline   Reply With Quote
Old 01-13-2011, 01:28 AM   #3
rjn72
rjn72's Avatar
sometimes a jar can knock a coil out. You might want to check the output of the coil.
JESUS IS LORD
87 crew cab V30 454/400
rjn72 is offline   Reply With Quote
Old 01-13-2011, 08:30 AM   #4
BigBlocksRule
Check everything electrical. Make sure the dizzy is clamped down tight.
edited the post to get rid of the useless chatter... lets keep this on topic
BigBlocksRule is offline   Reply With Quote
Old 01-13-2011, 01:51 PM   #5
pig rig
pig rig's Avatar
if it started running like crap after she hit you on the passanger side Id start with battery ground straps and other electrical on that side
my sports car rolls on six wheels only because I'm to fat to get in and out of new corvette
http://hubgarage.s3.amazonaws.com/ph...ped_detail.JPG
pig rig is offline   Reply With Quote
Old 01-13-2011, 02:13 PM   #6
jitteryguy
GoatLube Experss
jitteryguy's Avatar
I agree, I recently had similar trouble and it turn'd out to be a bad ground. sucks bout the hit !
Goat Lube Express, locations in Qalat,Afghanistan & Clarksville, Tn.
'87 R30 dually 454/TH400
'85 1/2 ton CCSB
'92 S10 350/350
'84 MonteCarlo 383/PG/9"ford
'78 Malibu wagon 350/350
'78 Cutlass (project family car)
'96 S10 Jimmy (Moma's)
jitteryguy is offline   Reply With Quote
