Old 01-13-2011, 01:51 AM   #1
old_1966_GMC
migth want to convert 65 gmc LB to a 4x4
i have a 1965 SBW longbed pickup i was wondering on what to do with it i wanted to put some 22'' wheel and stuff but i aslo enjoy going 4x4 on my 86 toyota p/u and always liked mudding how much can u spend in $ and everthing to make this 65 a 4 wheeler
old_1966_GMC is offline   Reply With Quote
Old 01-13-2011, 09:11 AM   #2
duallyjams
duallyjams's Avatar
Re: migth want to convert 65 gmc LB to a 4x4
The GMC already has leaf spring in the rear, GM simply put a 4 inch block in the rear for a 4x4. 65 had a divorce transfer case but you can use one from a later 4x4 that has a trans and case combo. You have to change some cross members and relocate the e brake and add front spring hangers and perches.
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 01-13-2011, 03:39 PM   #3
old_1966_GMC
are there lift kits that u can buy anywhere for my 65 gmc i know from 73-87 chevy trucks suspension bolts and fits just fine can i just look for a kit in that year range or no what are the ups and down?
Old 01-13-2011, 03:42 PM   #4
msgross
msgross's Avatar
does it have leafs on the front?
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 01-13-2011, 03:45 PM   #5
old_1966_GMC
will my 305E V6 4speed tranny have any trouble pushing big mud tires
Old 01-14-2011, 12:22 AM   #6
old_1966_GMC
no the front are coil spring and rear are leaf im also bout to be done rebuilding a front suspension i got from a 75 chevy c10 i really want to lift this thing but my problems are never delt with sumthin like this and dot know what ill be dealling with
Old 01-14-2011, 08:10 AM   #7
duallyjams
duallyjams's Avatar
Nope on the lift kit. If you want a leaf spring lift you would have use one from a kit that is offered and make it work by relocating frame mounts or you can go to a spring shop and have a set made.
James
IG duallyjams
Old 05-12-2011, 10:48 PM   #8
old_1966_GMC
ive seen some trucks today from 73 and up that seemed to be lifted with leaf springs and also looked like a rear end there were like 4 of them in that same way is this possible to interchange it to my gmc
Old 05-14-2011, 08:43 PM   #9
Dunenutt
Newbee
Dunenutt's Avatar
I spent $500.00 on a doner blazer that had everything I needed for the swap to a 69. I quit counting reciepts when I could not put the lid on the shoebox anymore. So it could cost $500 or could run you broke, like me.
Get a mid 80's 4x4 for a doner, and go from there.
Dunenutt is offline   Reply With Quote
