Old 01-13-2011, 02:00 AM   #1
Tkmadone
Door relief valve
I just put new seals all around in my '67 C20 and now it is really hard to close the door unless the window is cracked!
Is it possible to retrofit a relief valve from the later model to my cab? What would be involved in that? Where does the air go?
TIA
Tkmadone is offline   Reply With Quote
Old 01-13-2011, 02:18 AM   #2
78bronzechariot
78bronzechariot's Avatar
Re: Door relief valve
I'm going to start off by saying I'm jealous that you have your cab that well sealed. How about cracking the cowl vents just a little? Anyway, I don't see why you couldn't install the valves from a newer truck, just have to cut the right size hole and screw it in.
78bronzechariot is offline   Reply With Quote
Old 01-13-2011, 11:02 AM   #3
HuggerCST
HuggerCST's Avatar
There's no reason that it couldn't be done, but you could also install one from a '72 in the door jamb. '72s had a black plastic vent just below the driver's door striker in the cab.
Wynne
70 CST short fleet Hugger orange & white, 350/350, ps, pb, air, tilt, tach/vac/speedwarning, original buckets, AM/FM, oak bed floor, shoulder belts, 3.5"/5.5" drop, 20" American Racing VN425s.
Build thread
53 Chevy shortbed
69 Camaro
Click here to subscribe
Chevy GMC International Truck Club Louisiana Charter Member
http://www.louisianaclassictruckclub.com
HuggerCST is offline   Reply With Quote
Old 01-13-2011, 12:04 PM   #4
71 super
71 super's Avatar
71 and 72 had the vent. It was one of the changes they made in 71 to the cab, the others included the square hole for throttleand the raised pad for hanging rear view mirror (1 year only). You can get a used vent from one of these trucks, trace the outline of the backside and using a cut-off wheel cut the outline out, shape up with a square file and you have a cab vent. Be sure to use tape and tape off the areas around the cut so sparks dont screw up your paint. Hope this helps.
67 blue step side- bb
68 gold and white swb cst anniversary
68 custom swb hot rod Ls swap
69 swb cst 6 cylinder/ overdrive
69 black/black cst bb swb
70 orange and white cst Canada built truck swb bb
71 black and white super swb bb
71 red and white super swb
72 green and white super swb 4x4
62 nova wagon 400 series Ls swapped
68 Camaro 327/4 speed- 1 owner, original paint
66 Volkswagen bettle
69 auto stick Volkswagen Beetle
71 super is offline   Reply With Quote
Old 01-13-2011, 01:16 PM   #5
Tkmadone
So does the air come from the inside of the cab, through the valve, and into the space between the door and the jam? I'm just trying to figure out how it works.
Thanks for the responses!
Old 01-13-2011, 01:29 PM   #6
HuggerCST
HuggerCST's Avatar
Yep, you got it!
Wynne
Build thread
53 Chevy shortbed
69 Camaro
