Old 01-13-2011, 03:27 AM   #1
Yukon 400
Drive Shaft Help, 1 or 2 Piece?
I was wondering if you guys have any advice for choosing a drive shaft, right now there is just under 6 inches between the transfer case tail housing and the front of bearing support from the original two piece drive shaft. Th plans would be to run a drive shaft with double cardan joint, I know it's best to locate the joint at the same pivot location as the suspension which should be on the rear side of the bearing support, the question is how to get the joint in that location.
The solutions would be:
1. Run a two piece drive shaft with standard slip yoke, bearing support, with a very sort intermediate shaft.
2. Run a one piece drive shaft and new cross member with the joint located in front of the suspension pivot.
3. Run a one piece drive shaft and relocate the cross member forward and make some longer trailing arms to relocate the suspension pivot location
4. Relocate the engine and tranny further back to place the joint in the ideal location.
I just wanted to get some of your thoughts on which solution would be best or if there is another viable resolution to the problem, thanks.
Yukon 400 is offline   Reply With Quote
Old 01-13-2011, 09:15 PM   #2
Yukon 400
Re: Drive Shaft Help, 1 or 2 Piece?
Any thoughts?
Old 01-13-2011, 10:13 PM   #3
Willys47
Willys47's Avatar
1 or 2 Piece? I think there is only room for a one piece there.
I was hooked on these trucks since 1982 when I drove my budys fathers 1968 Custum GMC 396 automatic dana 60 rear with a power lock diff what a ride more fun then we will we can ever tell!!
Willys47 is offline   Reply With Quote
Old 01-13-2011, 10:26 PM   #4
Yukon 400
My problem is that the double cardian should be on the back side of the cross member where the trailing arms are attached to, or figure a way to get the two in the same location. The truck will be riding on air bags with a good amount of travel, so it would be nice to avoid vibration problems down the road.
Old 01-14-2011, 12:02 AM   #5
Willys47
Willys47's Avatar
take the steady bearing mount of the cross member and do a test fit it may just be enough room after the slip yolk for the carden to be happy.
Old 01-14-2011, 12:25 AM   #6
jmlcolorado
I just saw a post on here where a guy driving a lowered burb was running a 1 piece. He just removed the carrier bearing and the drive shaft cleared fine.
Maybe a test with some string with the bags in the highest and lowest position to see if you can clear without having to do a second piece?
jmlcolorado is offline   Reply With Quote
Old 01-14-2011, 02:27 AM   #7
Yukon 400
jmlcolorado Would you happen to remember who that was? Thanks.
It clears now, I had to elevate the tranny mount so a drive shaft would not hit the cross member at full droop.
1953 Chevy 6400 Truck - 2 Ton Pickup Project - 5.9 CTD, 6 Sp Allison, Air Ride, 22.5 Wheels
1952 Chevy 6400 Truck - Looking for a direction in life
