01-13-2011, 11:18 AM | #1 |
Retired Air Force Veteran
Electric Fan question
Are there any benefits to running an 16 inch electric fan on the outside of the radiator while running a stock clutch fan with shroud, (I think that would be pulling while the stock clutch fan would be pushing)
Motor is a 350 with 350 turbo trans and will have a 24" finned frame tranny cooler
Harry 69' SWB Step Side 1/2 Ton w/68' Front Clip Swap from Leafs to Trailing Arms (Complete) Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front) 3/6 Drop Help Support The Board Click Here For Information On How To Subscribe Krue's FAQ Page Vendors |
01-13-2011, 11:32 AM | #2 |
Re: Electric Fan question
The stock fan and shroud work by making a low pressure area just behind the radiator that draws air through it.
If this is not sufficient to cool a 350, then you have issues that should be addressed instead of trying to force MORE air through. JMHO....
Allengator Outta the Blue (my band - available for hire in the DFW area!) 1980 Chevy SWB Pickup (build thread) 1951 Chevy Sedan Delivery 2004 Chevy Tahoe Z71 2011 Harley Davidson Street Glide 2018 Silverado Z71 Crew Cab |
01-13-2011, 12:02 PM | #3 |
i was just asking cause i have an electric fan and was wondering if i should install that too. the motor runs fine with the clutch fan and shroud
01-13-2011, 12:39 PM | #4 | |
20' Daredevil (Ret)
BTW, your clutch fan is a puller.... an electric in front of the radiator would be a pusher.
01-13-2011, 12:56 PM | #5 | |
