Old 03-11-2003, 11:04 AM   #1
jddowell
Another Ram Horn Question
I have been told by several that straight dump Ram Horns will not work on my "72" due to lack of room. They tell me they must be the Ram Horns that curve back in order to clear. Since you guys on the board have experience with this, which is true: I need the curved back or the straight will work with no problems?
jddowell is offline   Reply With Quote
Old 03-11-2003, 11:47 AM   #2
Stout72
Not my good side.
Stout72's Avatar
I have straight dumps on my '72 and there's plenty of clearance. But mine's a 4x4; the motor is mounted back in the I-6 position.
See this post, it has a good explanation:
http://67-72chevytrucks.com/vboard/s...threadid=44042
72 Chevy K20 Custom Camper, 350/350, 4" lift, dual shock suspension front & rear. Daily driver and a work in progress.
00 Suburban LT
90 Camaro RS
79 Yamaha XS1100 Special (Ol' Reliable)
Stout72 is offline   Reply With Quote
Old 03-11-2003, 12:15 PM   #3
gman
I repeat what Stout72 says. Mine has straight and mine is also a 4X4. Stock, by the way!
72 Chevy SWB Custom Deluxe K10, 350/SM465, PS, PB, Fact. Air
2000 Harley...Wide Glide
gman is offline   Reply With Quote
Old 03-11-2003, 03:11 PM   #4
Long Knight
Spank 'em if you got 'em!
Long Knight's Avatar
I looked into putting straight dump on my 350 after the rebuild, but it wouldn't work for some reason, can't remember why. When it came down to it, I just couldn't spend that much on manifolds and got headers instead. If you don't mind me asking, why not install headers?
Long Knight
'71 C-20, 350ci, TH350, Edl. 1406 Carb w/elec.choke, Ignitor ignition, Viper Tires, Orange Dipstick
Long Knight is offline   Reply With Quote
Old 03-11-2003, 04:40 PM   #5
bigvinnie
bigvinnie's Avatar
I have a straight dump on the passenger side of my 2wd truck with a 350 mounted in the V8 position, works fine but the exhaust pipe must make a fairly quick turn rearward as soon as it leaves the manifold, to avoid the crossmember...
Angled style would be a better choice, but for those with the motor in the V8 position wanting to run the larger vette manifolds that only dump straight down, it's do-able...
'72 short step, 350, 700R4, tilt, ps, pdb, a/c, lowered coils, etc., other work in progress... San Diego, CA
72 Stepside Project
bigvinnie is offline   Reply With Quote
