01-13-2011, 12:53 PM | #1 |
Starting a new engine build.
The 383 is dead and I am now build a 406 for the 62. Down side I got ripped off on the first build. Upside I am doing this one and will be bumping the CI up so should be even more of a terror when I step on the pedal.
New build is 406 CI RHS heads 220CC 72 chambers, 2.055 in/ 1.610 ex ( I am porting them now) Comp cams XR294HR stick 1.5 rockers CP pistons Steel crank and h beam rods ( SCAT) PPI hurricane with a 750 DP demon carb compression 10.7.1 Should run very well with my gearing and tire size. Last edited by GMR-PERFORMANCE; 01-13-2011 at 01:07 PM. |
