Old 01-13-2011, 02:58 PM   #1
erikgto
My truck has a 400/700r4 and 2.74 rear..which rear to get for economy & peformance
Hi guys,
Found out that my '86 still has it's original 2.73 peg leg rear.
I will be running 385/40 or 295/40R20's.
Clearly the 2.74 is purely an economy gear and will have the 400 sbc lugging around.
I want to keep economy and relative low highway RPMs in mind, but I do think something like a 3.42 would be way better for performance without hurting my fuel economy.
What would you do, buy a complete used rear (sight unseen over internet) or swap ring and pinion?
1972 GMC 2500 Sierra 350
1971 Pontiac LeMans Sport 400 GTO/Judge Clone
1970 Pontiac GTO 400 convertible restoproject
1970 Pontiac Bonneville 455 convertible
erikgto is offline   Reply With Quote
Old 01-13-2011, 03:13 PM   #2
Jonboy
Slots go on anything!
Re: My truck has a 400/700r4 and 2.74 rear..which rear to get for economy & peformanc
I would swap to a 3.42 ring and pinion. Shipping would be a lot easier, and you would probably come out better in the long run.
1974 Jimmy- 5.3/4L80e/NP241
Old 01-13-2011, 03:23 PM   #3
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
3.42 or 3.73
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 01-13-2011, 03:43 PM   #4
benoit454
Chris
benoit454's Avatar
x2 at least 3.42 maybe as far as 4.10's if you have a tall tire since you'll have od, but really 3.73 would help give you fuel mileage. If you want more fuel mileage then power do 3.08.
Chris
GIT R DONE!!!!!!
Check out all our rides,
Old 01-13-2011, 03:46 PM   #5
Keith Seymore
Keith Seymore's Avatar
3.42 is usually my "default" setting.
By having an overdrive in this case, 3.73 might give you a bit more pep.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 01-13-2011, 03:52 PM   #6
Greenlee
Greenlee's Avatar
I did this on my 76' Silverado. I went to Pick-a-Part and pulled one with 3.73's. It was like a different truck with 3.73's.
I thought this was easier and cheaper than swapping out the gears, however, since you are in The Netherlands having a complete rear end shipped to you might not be that easy.
Greenlee is offline   Reply With Quote
Old 01-13-2011, 04:01 PM   #7
jchav62
1962 C-10
jchav62's Avatar
Since you have such a high gear ratio out back, just use Drive(3rd), and save the overdrive for that flats and downhills...
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 01-13-2011, 04:25 PM   #8
erikgto
Thanks for the response
I guess I'll be on the look for a 3.42 set.
With gasprices right around $ 8,- a gallon around here I'm leaning a bit more towards better mileage than quicker acceleration.
Might take the plunge and go for a posi at the same time.
If I get the urge to play I can allways get in my '71 Pontiac and go
Old 01-13-2011, 04:27 PM   #9
benoit454
Chris
benoit454's Avatar
yea you wouldn't need od with them gears but I would agree you need more pep for sure. I usually like alot taller gear for torque and take off and od helps out with rpm's.
Chris
GIT R DONE!!!!!!
Old 01-13-2011, 05:26 PM   #10
Clyde65
Clyde65's Avatar
is the truck you r play toy? do you live in the city, do you drive the highway alot?
If your playtoy, or you live in the city, then 3.73 is the way to go...
If your DD or you drive the highway alot, then 3.42 would be best
Clyde65
Rebuild of Clyde
support our troops!
Old 01-13-2011, 10:08 PM   #11
N2TRUX
Happy to be here
N2TRUX's Avatar
My experience has been with an OD transmission, a 3.42 is good for one MPG over a 3.73. The fun factor goes up considerably, but the 3.42 is a good compromise.
Keep in mind, you probably have a 3 series carrier, so a 3.73 won't fit unless you order a set specifically for the 3 series.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
