01-13-2011, 09:17 PM | #1 |
69' Chevy Stepside
Lowered My Truck Finally, 1969 C10 LSx Stepside
Well when I restored my truck I bought a 2/4 spring drop kit from CPP, anyways I'm not sure if since I have a aluminum headed LSX motor that its much lighter than a SBC 350 or what but the front of my truck with the 2 inch front drop springs sat way too high while the rear was nice and low. This was an issue so at the time I just jammed some lift blocks under the rear springs to bring it back up. I finally decided fixed it!!!
So I found my original front springs, and cut off a loop, sand blasted and painted them and removed the lift blocks in the rear, and installed the adjustable CPP panhard bar. This is a before shot: This is how it turned out after I cut the front springs and installed the rear CPP springs without the spacers: Keep in mind the front tires are smaller but from the top of the wheel well to the ground its 30.25 in the front and 30.75 in the rear. Some teaser engine pics, I absolutely can't wait for the month of May to come around so I can take the truck for a drive with the new motor!
-Matthew -69' Chevy Custom/10 Shortbed Stepside 2WD "Copperhead" - Restored, 6.0L LQ9 Built. L92 Heads and LS3 Intake with Comp Cam 223/231 .610/.617 112 LSA, 4L60E with Shift Kit and Circle-D 3200 Stall Converter ~Build Thread -1957 Chevy BelAir 2 Door Post Sedan, Full Frame off Restoration done myself - 6.0L with T56 six speed -1957 Chevy BelAir 2 Door Post Sedan - Nearly rust free AK car, Project in the waiting -2003' Chevy Silverado SS AWD 6.0L! - Daily Driver Last edited by matthew20061; 01-13-2011 at 09:21 PM. |
01-13-2011, 09:25 PM | #2 |
Re: Lowered My Truck Finally, 1969 C10 LSx Stepside
Looks great! You did an awesome job on the resto!! Is that a 47 flat deck hiding under cover I see..? Next project?
01-13-2011, 09:26 PM | #3 |
Nice truck!
01-13-2011, 09:27 PM | #4 |
I like it lots
Fuzzy |
01-13-2011, 09:28 PM | #5 |
I dun gradjiated collij!!!
Get that truck out of the snow and back in a nice cozy shop!
Seriously sweet ride, I always imagine Alaskan trucks to be rollin' swiss cheese from the rust...
Built NOT Bought. Viper Red 1971 LWB C10 355 Vortec W/700R4 4/5 drop AKA Screamin' You are missed!
2006 F150 XLT 5.4L Triton Rollin' on 22s the "F1" 67 C20 PS/AC/327/TH400 we call 'er "Bessie" 67 Malibu PS/ZR1-LS1 Brakes/350 Vortec/700R4 2/2 drop on 18" 338s - Tracy's "Boo" Boosted '67 Cougar EFI 5.0 HO roller motor/T5/8.8 Tracloc/ 4 wheel disks - "Project Panther" 79 Honda Z50 - stretched, cafe'd and hotrodded 125CC Lifan/5spd FEAR THE MONKEY! |
01-13-2011, 09:36 PM | #6 |
67-72 parts collector,…
You have a beautiful truck!
How did you mount the chevelle SS wheels? Adapters?
01-13-2011, 09:58 PM | #7 | |
69' Chevy Stepside
-Matthew -69' Chevy Custom/10 Shortbed Stepside 2WD "Copperhead" - Restored, 6.0L LQ9 Built. L92 Heads and LS3 Intake with Comp Cam 223/231 .610/.617 112 LSA, 4L60E with Shift Kit and Circle-D 3200 Stall Converter ~Build Thread -1957 Chevy BelAir 2 Door Post Sedan, Full Frame off Restoration done myself - 6.0L with T56 six speed -1957 Chevy BelAir 2 Door Post Sedan - Nearly rust free AK car, Project in the waiting -2003' Chevy Silverado SS AWD 6.0L! - Daily Driver |
01-13-2011, 10:10 PM | #8 | |
69' Chevy Stepside
Thanks!
Thanks! Quote:
Thanks! I thought the wheel conversion was pretty cool. To mount the SS 396 Chevelle wheels I used a front disc brake conversion kit from CPP for 5 on 4 3/4 wheels bolt pattern and then I got new rear axle shafts from Mozer for the bolt pattern. Then I had the rear drums redrilled to the new bolt pattern as well! The rears a 15x10's and the fronts are 15x8's.
-Matthew -69' Chevy Custom/10 Shortbed Stepside 2WD "Copperhead" - Restored, 6.0L LQ9 Built. L92 Heads and LS3 Intake with Comp Cam 223/231 .610/.617 112 LSA, 4L60E with Shift Kit and Circle-D 3200 Stall Converter ~Build Thread -1957 Chevy BelAir 2 Door Post Sedan, Full Frame off Restoration done myself - 6.0L with T56 six speed -1957 Chevy BelAir 2 Door Post Sedan - Nearly rust free AK car, Project in the waiting -2003' Chevy Silverado SS AWD 6.0L! - Daily Driver Last edited by matthew20061; 01-14-2011 at 06:06 PM. |
01-13-2011, 10:37 PM | #9 |
super nice truck
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
01-13-2011, 10:43 PM | #10 |
Tot Roddin'
Amazing stepper!
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
01-14-2011, 12:30 AM | #11 |
69' Chevy Stepside
01-14-2011, 01:28 AM | #12 |
Hey matthew20061 ... Very very nice!!!
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
01-14-2011, 01:23 PM | #13 |
69' Chevy Stepside
Thanks!
Thanks!
