Old 01-13-2011, 10:33 PM   #1
D.PASSMORE
One of the First
D.PASSMORE's Avatar
Cool '72 Horn button/parts
Well, I've searched the board, looked at the LMC catalog and played with the parts. I can't figure how to put the horn button, with parts together - and make it work. This includes the plunger parts (3 peices) that go into the canceling cam. Can I get a few pictures of the assemblies and the sequence of how they are installed.
DAVID PASSMORE
ST AUGUSTINE ,FL
ZIP 32084
'71 SWB K/10 CUSTOM DELUXE (Chili)
'72 BLAZER K/5 Muscle Truck (Mule)
'72 LWB K/20 CHEYENNE (Blackie)
D.PASSMORE is offline   Reply With Quote
Old 01-13-2011, 10:36 PM   #2
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Re: '72 Horn button/parts
I have this from when I had trouble with mine, its 67 68 but should be pretty close..
Good luck
John
1999 Toyota Tacoma 4x4
Old 01-13-2011, 11:18 PM   #3
71 super
71 super's Avatar
David, plinger/cancel cam goes into dedicated hole in wheel. Install wheel, install nut and washer then install the spring steel circle dome up, Install the retainer ring (part that horn button snaps into and the bushing into the center. It is important that the spring steel circle is not pinched against the side of the wheel- dont over tighten the retainer and you should be good to go. If this is not, simply flip the spring steel- the key is not letting it get pinched against the wheel side- this completes the circuit and causes the horn to work.
For the plunger, install the spring, the conection plunger and the small black or white plastic ring retainer. It is an interference fit much like the primary rods in the front of a quadra jet. It simply presses in and the inteference holds it in place. If you have the kit, they send two different plungers if I remember correctly and it uses the longer version I think. harold
67 blue step side- bb
68 gold and white swb cst anniversary
68 custom swb hot rod Ls swap
69 swb cst 6 cylinder/ overdrive
69 black/black cst bb swb
70 orange and white cst Canada built truck swb bb
71 black and white super swb bb
71 red and white super swb
72 green and white super swb 4x4
62 nova wagon 400 series Ls swapped
68 Camaro 327/4 speed- 1 owner, original paint
66 Volkswagen bettle
69 auto stick Volkswagen Beetle
71 super is offline   Reply With Quote
Old 01-14-2011, 12:02 AM   #4
D.PASSMORE
One of the First
D.PASSMORE's Avatar
Thanks for the picture, that did helped.
Harold,
Good write up, I'll play with it tomorrow and let you know.
Old 01-14-2011, 12:08 AM   #5
LockDoc
The Older Generation
LockDoc's Avatar
david,
Here is a thread that I posted some info in:
http://67-72chevytrucks.com/vboard/s...highlight=horn
LockDoc
Leon
