Old 01-13-2011, 10:34 PM   #1
86k30
sm465 to Nv4500
Does the floor need to be cut to make room for the transmission and transfer case shifters with an nv4500 swap. It is a pre 1995 nv4500.
The truck is an 86 1 ton with a 350SBC, sm465, and a np205
86k30 is offline   Reply With Quote
Old 01-13-2011, 11:25 PM   #2
BigRed76
BigRed76's Avatar
Re: sm465 to Nv4500
The NV4500 will fit under the floor just fine. the only thing you will have to cut is a new hole for your transmission shifter because the shifter on the nv4500 is about 4 to 5 inches farther back. Most people just get a floor hump from an automatic truck and cut the new hole. Im not exactly sure if the location of the t-case shifter changes.
Zach
1970 Chevrolet Custom Camper K20
1971 GMC Super K2500, 12V/NV4500 swap in progress
1971 Chevrolet Custom C10
1972 Chevrolet Custom Deluxe C20, 5.3/4L60E
1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi
2004 GMC Sierra 2500HD, LB7/Allison, CCSB
2005 GMC Sierra 1500, 5.3/4L60E, CCSB
BigRed76 is offline   Reply With Quote
Old 01-14-2011, 12:40 AM   #3
bmchevy1979
bmchevy1979's Avatar
Re: sm465 to Nv4500
This might help http://67-72chevytrucks.com/vboard/s...d.php?t=431033
<Brandon>
1974 Chevrolet K5 Blazer 350sbc/SM465/NP205, dana44 front, corp 14bolt rear with 4.10s and a powertrax locker, custom rear bumper 400sbc in the works.
1981 GMC C1500 stepside 250i6, 3spd, 12bolt with 3.08s 2.5/4drop on 15x10 with 275/50r15
81 GMC C3500 cab-chassis dually with utility bed 350sbc, Sm465, 14bolt with 4.10s nv4500 getting ready to go in
1979 Chevrolet K5 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434096
1976 Chevrolet C10 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434195
bmchevy1979 is offline   Reply With Quote
Old 06-02-2011, 09:48 PM   #4
my4by2
my4by2's Avatar
Re: sm465 to Nv4500
Not the best pic I'm afraid, but maybe you can make out how the NV4500 sits in the floor of my truck. It's an original SM465 truck.
1977 Chevrolet K30 LWB Crew Cab
497HP Mast Motorsports 6.0L LY6 HO engine
GM NV4500 5-speed, Centerforce clutch + NP205
D60 + 14-bolt FF w/ Eaton posi + disc brakes
Skyjacker 2.5" full spring lift w/ Nitro shocks
Custom paint + interior
http://67-72chevytrucks.com/vboard/s...d.php?t=435722
my4by2 is offline   Reply With Quote
Old 06-02-2011, 10:15 PM   #5
ozark
Re: sm465 to Nv4500
I had a truck with a n4500 with a 205 transfercase. when I got the truck they had a piece of mud flap and towel wraped around the 2 shifters. The trans shifter and the 205 shifter were almost side by side, infact the hole for the trans and transfercase were not divided. I used a shifter boot out of a 95 chevy truck with a nv4500 and the stock 205 shifter boot. I had to do a little fabing and conect the 2 boots together at the mounting rings, its been a long while back can't seem to remember why I didn't weld a strip between the 2 shifter holes. I didn't cut the hole for the nv 4500 so I don't know if a strip of floorboard between the two shifters could have been saved. The transfercase shifter location remained in the same location as stock.
ozark is offline   Reply With Quote
