All around good guy
Carryall Patch Panel
I have rot above the rear wheel wells near the lip. Does anyone have first hand knowledge of what patch panel can be made to work with this?
There are several truck patch panels that "look" like they would work. Bullington |
Re: Carryall Patch Panel
what kinda truck u talking about?
well the title says carryall.
the fleetside panel should do you. you can buy that that section ron |
All around good guy
Sorry it is for a 1966 Caryall. I was guessing fleetside was similar. I'm not going to be so lucky with the rear quarter panels though. Unless I find one that has been totaled in the front maybe.
Bullington |
you have a PM
ron |
I just made the quarter patch panel out of my brothers 82 door. Not great but not bad. Fit better than some aftermarket panels. Would be easy if you have a useable bottom rear corner. Took longer to make that than all the rest.
Posted via Mobile Device |
60-66 Nut
![]() ![]() Join Date: Mar 2007
You can use the aftermarket patch panels that are for the short fleetside. The wheel opening is the same as the Suburbans and Panels.
