Old 01-14-2011, 02:43 AM   #1
Deabt54
Deabt54's Avatar
Little help, C4 IRS
So I'm asking for a little help from those of you that have used a C4 IRS. I've got a 54 5 window with C4 IFS using a Progressive cross member. I'm r getting ready to install the rear, I'm going to set up the brackets myself and op out of using a Flatout or Progressive kit. Two things I hope someone can help me with.
1. I've got the distance between centers front and rear for the wheel base. Does anyone know the distance from the batwing like bracket to the axle center line of the third member. I figure if know that distance I could just measure back from the center line on the frame and mount the brackets. Make scene?
2.I'm going to run Aldan coil-overs, so this is out to you guys that are useing them what size and what spring rate are you using? And how much sage did you allow for?
Will I hope that all makes sence its kind of late.
I'll be posting more pics soon. Thanks in advance.
http://www.67-72chevytrucks.com/vboa...d.php?t=419646
Deabt54 is offline   Reply With Quote
Old 01-14-2011, 12:51 PM   #2
Thinkblue4 Evr
Thinkblue4 Evr's Avatar
Re: Little help, C4 IRS
For the shocks I would call Aldan Eagle and when we got ours the guy i talked to was very helpful and if you explain what you want they should give you what you are looking for. I will look at what ours is at for a measurement axle line to bat wing.
1952 Chevy 3100
1986 Corvette Suspension
350 motor Tune Port Injected
Thinkblue4 Evr is offline   Reply With Quote
Old 01-14-2011, 06:23 PM   #3
Deabt54
Deabt54's Avatar
Awesome, thanks for the help.
