Old 01-14-2011, 03:41 AM   #1
CEE1NG_RED
Dip stick tube loose...HELP!
My transmission dipstick tube is wobbling when I check the level, how do I fix this or tighten it?? Novice @ hand...
CEE1NG_RED is offline   Reply With Quote
Old 01-14-2011, 03:52 AM   #2
dave2953
Dave's not here, man
dave2953's Avatar
Re: Dip stick tube loose...HELP!
Is there a bolt that secures it? If so, check to see that it's tight. Also, it should have an o-ring that fits around the base of the tube and gives it a secure fit to the transmission. What kind of transmission is it?
- 2014 VW Jetta
- 2015 VW Jetta
- 1966 Ford F-250
dave2953 is offline   Reply With Quote
Old 01-14-2011, 03:58 AM   #3
CEE1NG_RED
I have no clue what tranny it is...I believe it's stock. I'm the 3rd owner, just purchased it a week ago for $2400.
Old 01-14-2011, 04:11 AM   #4
timber rattlesnake
well its automatic if u want easy fix but redneck at heart jerk pan and tube replace o-ring and the reaseon for jerking the pan is this cut stick to taper bottom edge of tube slightly works great for keeping water out of 4x4 trannys as well
timber rattlesnake is offline   Reply With Quote
Old 01-14-2011, 07:49 AM   #5
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
There is a tab with a bolt hole welded to the tube. It is secured with one of the engine to trans bolts. It sounds like someone has unbolted it in the past.
Old 01-14-2011, 11:07 AM   #6
CEE1NG_RED
huh?? What did you say? You lost me there...
I see... I guess I'll be checking the tranny area tomorrow. Thank you.
- 1967 Chevrolet C/10 SWB fleetside (New Project).
- 1969 Chevrolet C/10 SWB fleetside (SOLD)
- 2000 Ford Mustang 232 (DD)
- 2003 Ford SVT Cobra "Terminator" 281 (Once in a blue moon driver/weekend driver)
