Old 01-14-2011, 12:47 PM   #1
wrench_65
need help with shocks????
i have a 65 that i lowered 5 inches in the back and have 2 1/2 inch drop spindles with 1 inch lower springs in the front. i was wondering what schoks are being used. am on a budget wanted to see if there was some i can just pick up at the local parts store for the time being. Till i have enough to buy some decent lowering schocks. thanks
wrench_65 is offline   Reply With Quote
Old 01-14-2011, 02:02 PM   #2
vin63
It's Better With Nitro
vin63's Avatar
Re: need help with shocks????
You can go the Monroe Monro-Matic Plus route:
Fronts: 33033
Rears: 31000
around $20-$30, depending on where you find them...or, an economical cross reference.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
Last edited by vin63; 01-14-2011 at 02:21 PM. Reason: missed a 0 on the rear shock part number
vin63 is offline   Reply With Quote
Old 01-14-2011, 02:13 PM   #3
wrench_65
thanks...
Old 01-14-2011, 03:02 PM   #4
mannyb.
mannyb.'s Avatar
i run cpp's nitrogen shocks. they're actually doetsch tech nitro slammers. you could shop around but usually run about $40 per. you're gonna spend the money on the shocks anyways, no sense in spending it twice. theyre a little bit stiffer but i like sportier suspension.
sizing chart http://www.classicperform.com/Catalo...hock_Specs.pdf
1963 LWB C10. tired 230. soon to be sbc350!!!!
i just wanna go fast!! shake & bake, baby
mannyb. is offline   Reply With Quote
Old 01-14-2011, 04:21 PM   #5
65Gregg
65Gregg's Avatar
Have you relocated your shock mounts yet? If not it won't really matter what shocks you use, they don't work well at the angle that a 5" drop creates...just my .02 worth.
65Gregg
Blue long bed
White TBSS
61 Impala
“The two most important days in your life are the day you are born and the day you find out why.” Mark Twain
65Gregg is offline   Reply With Quote
Old 01-14-2011, 05:19 PM   #6
jimmydean
jimmydean's Avatar
Fronts: 33033
Rears: 31000
Not to hijack, but aren't the stock rear shocks too long with a 5" drop?
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 01-14-2011, 07:34 PM   #7
vin63
vin63's Avatar
Those are the shocks that are included in the Cool Ride system from Air Ride Technololgies, now Ridetech. IIRC, the rears have a collapsed length of 10 inches, which is about the same as the Nitro/CPP rear shock application for a 5-inch rear drop.
Old 01-14-2011, 07:40 PM   #8
mannyb.
mannyb.'s Avatar
Gregg's right, i forgot about that. I too, dropped my rearend 5" and you definitly need to relocate the mounts. as well as a c-notch.
Old 01-14-2011, 07:54 PM   #9
jimmydean
jimmydean's Avatar
Perfect, Rock Auto has all 4 for under $80, can't beat that!
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
Old 01-14-2011, 08:01 PM   #10
lakeroadster
Hey Vin63, thanks for posting the data for the Monroe shocks... I am needing a new set of shocks also and don't want to go with the harsher aftermarket stuff.
Did you relocate the shock mounts? This is the first I have heard about needing to relocate shocks. I'd like to hear from some guys that did not relocate the shocks for some real world experience as to if it is really required.
Vendors are pushing product.... and will tell ya to do this or that, when it may not really be necessary.
Oh, and a c notch is not mandatory with a 5" drop. I am driving proof of that. Bump stops are a wonderful thing.
Thanks in advance.
lakeroadster is offline   Reply With Quote
Old 01-19-2011, 12:01 PM   #11
vin63
vin63's Avatar
Thanks in advance.
No problem...my buddy did not relocate his shock mounts on his '66, and he went with the Montro-Matics because he found the nitro shocks were too stiff of a ride for him. And, he has about a 3-5 static drop.
Old 01-19-2011, 04:00 PM   #12
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Fronts: 33033
Rears: 31000
Are these stock shock numbers or shorter ones that will work for our trucks?
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 01-20-2011, 02:12 PM   #13
vin63
vin63's Avatar
IIRC, these are the stock replacements, but the Monro-Matics have a great deal of travel over other shocks.
Old 01-20-2011, 02:26 PM   #14
bama63
bama63's Avatar
great info
Due to financial constraints, the light at the end of the tunnel will be shut off until further notice
bama63 is offline   Reply With Quote
Old 01-20-2011, 05:35 PM   #15
Heater63
Heater63's Avatar
Originally Posted by bama63 View Post
great info
Yes it is! I thought we would have to use aftermarket with 3/4/5 and more drops- I've always like Monroe's. Too bad I already bought my CPP/Doestch. I hope they're not too stiff.
292 + TKO500
Heater63 is offline   Reply With Quote
Old 01-20-2011, 06:05 PM   #16
jimmydean
jimmydean's Avatar
With a static drop, maybe. With bags, I decided to go with the full travel. The lower shocks have less range.
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
Old 01-20-2011, 06:11 PM   #17
Heater63
Heater63's Avatar
Yeah, sorry, I was talking static drop.
292 + TKO500
Old 01-20-2011, 06:44 PM   #18
jimmydean
jimmydean's Avatar
I ran the CPP shock kit on my '69 when I first bagged it but went back to stock to get full lift. I will relocate the mounts on the rear.
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
Old 01-20-2011, 06:55 PM   #19
dallas71
dallas71's Avatar
Not to HiJack but what is the lowest Static Drop you can go without a C-Notch??? and what kit do you buy for the rear for shock relocation??
dallas71 is offline   Reply With Quote
Old 01-20-2011, 07:06 PM   #20
lakeroadster
I am running 5" drop rear CPP springs without a c-notch. I have about 3-3/4" clearance.
Old 01-21-2011, 11:17 AM   #21
65Gregg
65Gregg's Avatar
THe stock shock brackets can be modified to relocate the shocks, I can't remember who did a write up on it. I saw it on the suspension forum. I have a 4/5 and don't have a C notch either. My only complaint is my rear shocks are are too firm for my liking(my wife doesn't like it either).
65Gregg
Blue long bed
White TBSS
61 Impala
Old 01-21-2011, 03:38 PM   #22
scum1
scum1's Avatar
how exactly do the shock relocaters work. do they bring the shocks upright only, or do they also allow move up for more travel because of the drop..
scum1 is offline   Reply With Quote
Old 01-21-2011, 05:01 PM   #23
65Gregg
65Gregg's Avatar
They move the shocks back to a more vertical or upright angle. When the truck is lowered the shocks really lay down at a more horzontal angle and can't operate as intended.
65Gregg
Blue long bed
White TBSS
61 Impala
Old 01-21-2011, 06:44 PM   #24
SCOTI
SCOTI's Avatar
They also increase the amount of stroke the shock has for travel....
http://67-72chevytrucks.com/vboard/s...d.php?t=359399
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 01-21-2011, 08:36 PM   #25
Rich 5150 69
Rich 5150 69's Avatar
At the same token we build street rods with 18 to 23 degrees of shock angle for better axle control......so I`m thinking if your close to being in line with axle travel angles your still good.
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
