new speedometer cable but odometer still reads off
so i put in a new speedo cable from truckandcarshop. the speedometer works like a charm. but the odometer only moved .3 miles on my 8 mile drive to work. any suggestions?
thanks in advance
1963 LWB C10. tired 230. soon to be sbc350!!!! i just wanna go fast!! shake & bake, baby |
Re: new speedometer cable but odometer still reads off
My guess would be that the odometer gear is cracked and broken. I only say this because I just went through the same issue. They don't make any aftermarket ones that I could find. I ended up buying another cluster from a board member and taking the gear out of it. maybe it just hasn't broken completely off and that's why it registers some of the time.
k. how difficult is it to get to the gear for inspection?
Not too difficult, but you'll have to pull the cluster out. I'd never pulled one apart before and I did it in a couple of hours. Just be careful to remember how everything goes back together. Mine was broken in half, and once I got the cluster out, with a little moving, I could hear the broken peice rattling around inside. Here's a pic of the broken peice on mine. I'm sure someone else will chime in if I'm leading you down the wrong path.
i have one if you need it.i paid $25.00 for the entire cluster. i took apart the entire head cleaned and re lubed all moving parts and set the odometer back to showing zero miles and tested it for 4 miles.the only problem is i broke the end off the main shaft removing the needle so you would have to use your drum and needle and they are pretty simple after you get into it.i have gone through many of these in the past but this is the only one that has ever broke on me.but if you have a spare head for parts just pay close attention to what screws go where.good luck!
good lookin out. $25 sounds well worth the headache of trying to find just the gear itself. heres another funny one, on my way home that night when it only went .3 miles, it showed i went 4miles ??? i guess i just need to pull it out and inspect the gear. maybe it just needs lube?? what kind of lube would you recommend if thats all it is
#7 | |
thanks for the help! it wasnt as bad as i thought the hardest part was knowing that i chipped my paint when i pulled the cluster out. but the gear wasnt broken. mine is metal??? but it did look a little stripped though. i lubed it up like you said and gave it a test w/ a drill and the old cable. beautiful! thanks again, if it does go completely out, i will contact you for one.
1963 LWB C10. tired 230. soon to be sbc350!!!! i just wanna go fast!! shake & bake, baby Last edited by mannyb.; 01-19-2011 at 01:32 PM. |
#9 | |
take care. |
