01-14-2011, 06:10 PM | #1 |
Front Suspension "kit" for 1 ton??
We're getting ready to pull the front suspension apart on our 70 GMC 1 ton and was wondering if any or all of the parts from the 1/2 ton kit is the same as our 1 ton truck? I can't seem to find any kits for the 1 ton and some of the parts do seem to carry the same part #.
Any help would be most appreciated. Thanks, Tony |
01-14-2011, 07:20 PM | #2 |
AIRBAGPARTS.COM
Re: Front Suspension "kit" for 1 ton??
Everything should be the same. Only thing I would maybe change is the size/thickness of the bags.
01-14-2011, 07:24 PM | #3 |
Depends on what you mean by "kit". As Jason said, I would use a Slam 8" front bag, but the plates and cup are the same on my C20 as my C10 was.
I know there are frame differences, but if you are just swapping the coils for bags, then it's the same gear.
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 |
01-14-2011, 08:54 PM | #4 | |
67-72 parts collector,…
(as in bushings, balljoints, and tie rod ends)
01-14-2011, 09:04 PM | #5 |
I was referring to rebuild kit as in ball joints etc. This is a tow truck so air suspension is probably out of the question
Posted via Mobile Device |
01-14-2011, 09:15 PM | #6 |
I assume your truck is still has drum brakes up front.
Most auto parts stores have the parts, or should be able to order them. (alot of 67-72 parts aren't "in stock",... because there's not much demand for them) The lower balljoints are definitely bigger on the 3/4 and 1-ton trucks because the hole in the lower a-arm is larger than the 1/2 ton version. Tie rods should also be bigger. If you can't find parts locally,... I would look at Early Classic Enterprises. (ECE) www.earlyclassic.com.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 01-14-2011 at 11:34 PM. |
01-14-2011, 11:11 PM | #7 |
Are the 1 ton parts the same as the 3/4 ton trucks? I can't seem to find any front end parts listed for 1 ton, just 1/2 or 3/4. Very confused.....
01-14-2011, 11:38 PM | #8 |
I would shop for 3/4-ton parts.
The 73-87 3/4-ton and 1-ton parts share balljoint and tie rod part numbers. I assume the older 67-72 C20 and C30 truck would also. Maybe someone else can add some info?
01-15-2011, 09:29 AM | #9 |
I am pretty sure the ball joints and tie rods are the same. Not sure on the controll arm shafts.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
