Old 03-16-2002, 08:57 PM   #1
conman
Post tv cable on a 3 speed?
I'm transplanting a small block with a 350 tranny out of a 89 caprice, into 3/4 ton 75 chevy truck. On the cars gear selector was drive:1st;2nd, only. Which I think should be a 3 speed only, but there is what appears to be a tv cable from the carb to the tranny? Is that right? I thought only overdrive tranny's had tv cable.
Fayette Alabama
conman is offline   Reply With Quote
Old 03-16-2002, 09:07 PM   #2
low 84
low 84's Avatar
Post
i think what your seeing is the kickdown cable. this connects to the passenger side of the transmission and the connects to the bottom of the throttle linkage on the carb (its on all th350 trannys). it is not a tv cable like an overdrive has to control the transmission. it just tells the tranny when you really stomp on the throttle to kick down to a lower gear. the modulator on the th 350 is vacum controled unlike on the overdive which are controlled by the tv
BTW 79big10 just helped me replace this cable on mine yesterday
hope this helps
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works
'05 1500 Crew Cab
RIP
'84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker
'80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's
low 84 is offline   Reply With Quote
Old 03-18-2002, 02:59 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Post
The main differance between a kick down cable and the TV cable on the overdrives is the TV controll fluid pressure and the downshift cotrol. The Kick down only controls the down shifting whe you floor it.
You can leave the kick down disconnected with no accelerated tranny wear.
'69 G.M.C. 350/350. Trying to clean up the left over damage from the Dope-Smokin-Old-Man
I've been dubbed the Longhorn Freak/Fanatic/Expert, I just hope I can live up to it.
Need to pick up the one ton Longhorn with a PONTIAC 350/350soon.
Thanks every one!
Check out The Longhorn Webite.
If you need a pic posted, E-mail me at longhornmail@yahoo.com
Andy, in Columbus Ohio
