Old 01-15-2011, 12:46 AM   #1
mwilliams5891
Engine Build
Ok so this is my first engine build and I have a 327 from a 64 impala I think. It has the lower end done...not completely sure on what crank pistons or anything.
but for the top end i was planning on doing
http://www.summitracing.com/parts/CMB-08-0034/
I don't know what a good cheaper carb i should use so please help with that.
is this going to work for the carb?
http://www.summitracing.com/parts/HLY-0-80555C/
Engine dress up
http://www.summitracing.com/parts/PRO-141-758/
I was thinking this disturber but im not sure about it, as far as advances etc.
http://www.summitracing.com/parts/SUM-850001R/
cheap headers
http://www.summitracing.com/parts/SUM-G9006/
Water pump
http://www.summitracing.com/parts/TFF-1449NA/
Starter
http://www.summitracing.com/parts/TFF-3510A/
Alternator
http://www.summitracing.com/parts/TFF-7935ABULL/
so other than that i dont know the rest yet...so I know I missed alot so ask and please give advice and tell me if these will work and what else I need.
can I use my old fan? do I need to buy pulleys? flexplate? will my old 4 speed mount up (on an inline 6 now)
ok so any questions just ask........im planning on doing this next weekend or just after if anyone is around eugene/albany area of oregon
thank you all in advance
-1969 C/10 Short Step soon to be Brand NEW Ls6/T56
-03 Mazda Protege 5
-WTB 1970 Chevelle project
mwilliams5891 is offline   Reply With Quote
Old 01-15-2011, 01:22 AM   #2
hdandd
hdandd's Avatar
Re: Engine Build
if you get the cheaper painted headers, like me, make sure and repaint them with the 2,000 degree paint BEFORE you put them on...
hdandd is offline   Reply With Quote
Old 01-15-2011, 02:53 AM   #3
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
Re: Engine Build
Originally Posted by hdandd View Post
if you get the cheaper painted headers, like me, make sure and repaint them with the 2,000 degree paint before you put them on...
x2
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
Old 01-15-2011, 03:23 AM   #4
mwilliams5891
Re: Engine Build
ok thank you for that I wouldn't have thought about that
-03 Mazda Protege 5
Old 01-15-2011, 05:32 AM   #5
mwilliams5891
Re: Engine Build
so what kind of Rockers do I need? and do I need special kinds of push rods? I want to stay pretty cheap just so you all know
-03 Mazda Protege 5
Old 01-15-2011, 11:50 AM   #6
rick0312
rick0312's Avatar
Re: Engine Build
i purchased an edel intake and carb. price was under 300 for carb. i think the intake was about 100 bucks. install was easy. new crate engine fired right up!
http://www.summitracing.com/parts/EDL-1406/
69 C10 LWB GM 350 crate motor, 3.73 rearend
rick0312 is offline   Reply With Quote
Old 01-15-2011, 12:01 PM   #7
BIGBLU 72
BIGBLU 72's Avatar
Re: Engine Build
you have to get self aligning rocker arms for the Vortecs! push rods are the same as a stock small block. you might be able to get a good set off a 96-00 chevy/gmc truck at a junk yard for pretty cheap on the rockers
68 C10 LWB 2/4 drop 406/th400/3.73posi
04 Silverado SS LQ9 6.0/4L65e/4.11posi AWD
BIGBLU 72 is offline   Reply With Quote
Old 01-15-2011, 02:11 PM   #8
mwilliams5891
Re: Engine Build
THANK YOU!!! that is exactly the information I am looking to get!
so will these work good?
http://www.summitracing.com/parts.aspx?sku=CCA-1417-16
-03 Mazda Protege 5
Old 01-15-2011, 02:18 PM   #9
mwilliams5891
Re: Engine Build
So I was also looking at some comp cams for some increased power and I love the rough idle sound and on jegs they said that the biggest I could go without changing anything is this one
http://www.summitracing.com/parts/CCA-CL12-211-2/
but on the summit website says this.
"Designed for hot street/strip cars, these COMP Cams Magnum series cam and lifter kits require a higher compression ratio, rear-end gear ratio, and stall torque converter than stock."
I dont know how to check my compression ratio or exatcly what I should be trying to get. IM NOT BUILDING a race truck or anything like that. I just want to have some fun with it when I want. I was reading this thread below and It got me a little spooked about compression ratio, should I be worried about what it is talking about?
http://67-72chevytrucks.com/vboard/s...d.php?t=440319
-03 Mazda Protege 5
Old 01-15-2011, 02:21 PM   #10
mwilliams5891
Re: Engine Build
also are these pushrods going to work ok?
http://www.summitracing.com/parts/CCA-7812-16/?rtype=10
-03 Mazda Protege 5
Old 01-15-2011, 02:25 PM   #11
mwilliams5891
Re: Engine Build
oh also I dont remember the thread but what do I need to put on my head studs? (i know locktite is good) but It was because its in contact with the water
-03 Mazda Protege 5
Old 01-15-2011, 02:28 PM   #12
hchad18
hchad18's Avatar
Re: Engine Build
I went with a comp cams 260 on my 327 with the vortec heads. When I got my Vortecs I do believe I read that they have lift limitations with the stock springs. You dont want the springs binding @ full lift. You can also get your rockers off Ebay pretty cheap.
hchad18 is offline   Reply With Quote
Old 01-15-2011, 02:55 PM   #13
mwilliams5891
Re: Engine Build
so I am looking at the right kind of rockers right? and are you saying you had to change something on your vortec with the cam or it just has "limitations"?
-03 Mazda Protege 5
Old 01-15-2011, 03:16 PM   #14
hchad18
hchad18's Avatar
Re: Engine Build
Your looking at the right rockers. The stock valve spring on vortec heads can only handle so much lift before binding.
"The factory Vortec heads use a light, single-wire valvespring with a damper that generates between 70 and 80 pounds of load on the seat. Because these heads are meant to work with a 1.5:1 rocker, their tall valve guides can only handle maximum valve lifts of around 0.420 inch."
Old 01-15-2011, 04:55 PM   #15
mwilliams5891
Re: Engine Build
so then if i get a cam I need to make sure that it doesn''t lift more than that. correct?
-03 Mazda Protege 5
Old 01-15-2011, 08:00 PM   #16
hchad18
hchad18's Avatar
Re: Engine Build
I'm pretty sure I have a Crane cams 260 in mine which has .450 lift. I've read different articles on this issue so I would research it a little more. So yes whatever lift is that the stock springs can handle, don't go over that.
Old 01-16-2011, 03:47 AM   #17
Jacfourteen
Re: Engine Build
From what I've read the problem is that when you go over the recomended lift the spring retainer smashes the valve seal, causing oil leakage/burning. Here is a thread that a guy on here wrote a month or two ago. Go towards the end and you can read about the clearance problems he had and how he solved it.
http://67-72chevytrucks.com/vboard/s...d.php?t=429865
Old 01-16-2011, 03:52 AM   #18
Jacfourteen
Re: Engine Build
Forgot to mention, I've also read that the vortecs don't flow anymore past .480, so a bigger cam doesn't net you any extra HP. I had a thread going a while back and some guys told me my cam is about the biggest you would want to go, it's a comp cams xe268h. Here is a video of how mine idles/runs, for the rest of my specs look in my signature.
Old 01-16-2011, 03:02 PM   #19
mwilliams5891
Re: Engine Build
I like the sound of your idle! so the cam I am looking at is a little less lift than your so it should be fine right? so i forgot do i need to change anything for it to work?
-03 Mazda Protege 5
Old 01-17-2011, 12:56 AM   #20
mwilliams5891
Re: Engine Build
ttt
-03 Mazda Protege 5
