Cab mount install order
Hey guys,
gonna attempt to install the rubber cab mount kit from classic parts tomorrow and need a little reassurance. I didn't know this, but i guess that kit comes with the core support mounts too? NOT bad for $75! anyway, is the picture below the correct order of the parts? I assume the spacers in the kit are for the front cab mounts, and I reuse the core and rear cab mount spacers?? also, I reuse the bolts for the core and front mounts, right? Let me know if I am in order. Thanks!
1971 C-20 350/350 |
Re: Cab mount install order
check out this thread
http://67-72chevytrucks.com/vboard/s...318544&page=18 page 18 post 446 i'm not sure if yours is different but it should get you going in the right direction mike |
Well, got em installed...thought it would be a couple hours...ended up taking 8. So, as soon as I got them in i shut the doors, and ah! They dont close! She must have been saggin quite a bit! guess I have a task for tomorrow...
I also realized a couple of things. 1) working in an uninsulated garage in MN in January is really stupid. 2) Believing a 40 year old bolt will just loosen with PB Blaster will lead to dissapointment. All in all, I'm glad i dont have to screw with cab mounts for a VERY long time to come.
1971 C-20 350/350 |
Grandpa in the rustmobile...
How was the ride after? Did it effect handling/ride/quiteness? Etc, this is on my list to do in the near future, looking to see how important it is..
Thanks ![]()
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
#5 | |
![]() I've heard that all those things above will be improved...cant wait to see!
1971 C-20 350/350 |
Let us know!! Thanks
The one thing I can say is that cab shakes in unison with the rest of the truck, so the body roll is way less.
The problem I have now is that I can't get my doors to shut. I replaced all the cab mounts with new shims, but didn't add any more or less than what was there originally. I tried to adjust the door strike plates, but I can't move them down far enough to engage the latch. it is the same on each side....both doors hit the jam low. Anyone know what I need to do?
1971 C-20 350/350 |
