01-15-2011, 02:34 AM | #1 |
Can we talk about converting 4wd to 2wd?
I have a few questions is it possible to do with keeping a solid front axle? do hey make drop leaf springs? or would I be better off flipping the spring perches around? also what should i do with the axle keep the housing emspty and remove the axle shafts? I know if anyone can lead me in the right direction it will be you guys |
01-15-2011, 02:45 AM | #2 |
Factory Strippers Rule!
Re: Can we talk about converting 4wd to 2wd?
I'm not sure I understand... Why would you want to turn a 4x4 into a 2wd? If it's for gas mileage, I don't know that it would help if you already have hubs that can be unlocked. If it is for looks, I'm sure you could find plenty 'o people that would gladly trade their 2wd for a 4wd, given similar condition, etc. I guess it CAN be done, just like I can get a tattoo of Liberace on my back. But just because you CAN do something doesn't necessarily mean you should.
But then again, I do like 2wd's more than 4wd's...
"Feast your eyes on a feast of smoke." 67 Chevy Short Fleet PLAN: LQ9, 4L60, D60 Looking for School Bus Gauges - Help me out! |
01-15-2011, 02:51 AM | #3 |
I have been trying to get people to swap and trade and I have also tried selling ti for a 2wd but it's not happening so the only thing left is 4wd to 2wd
01-15-2011, 03:15 AM | #4 |
Post some pics. there are a lot of guys here that have multiples they might be willing to trade....just like trading baseball cards!
I personally want a 4x4 3/4 ton to match my 2x4 3/4 ton
1971 C-20 350/350 |
01-15-2011, 04:53 AM | #5 |
Collector of Projects
go find a 73-87 C10 and take the front crossmember and all parts attatched to bolt into your frame.... its been done and usually only requires drilling a few holes to bolt in....
If you want to keep the front you have, you could put the springs UNDER the axle tube. that would lower the front. Yes, take all the axles and locking hubs out. less rotating mass/resisitance.... but you're stuck with 6 lug and huge hub bore.... |
01-15-2011, 10:12 AM | #6 | |
You really can't lower a straight axle 4x4 to the point of it looking like a 2 wheel drive. The axle housing will hit the oil pan, no way around it.
If you really have your mind set on the conversion, you need the entire front crossmember from a 2 wheel drive truck. It's pretty much a bolt-in thing, but it would be a lot easier if you pulled the engine out first. It shouldn't be that big of a deal since you have to swap transmissions anyway to get rid of the transfer case.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. |
01-15-2011, 10:43 AM | #7 |
Thank you very much guys
01-15-2011, 10:43 AM | #8 |
05 Crew cab I with you were closer
01-15-2011, 12:20 PM | #9 |
"brand new second-hand"
x2
Steve 69 3/4t custom camper tilt,am/fm,speed warning,air gauge,buddy buckets,aux battery, big block,p/s,p/b,a/c 67 Camaro 96 Impala ss-sold 04 hybrid Honda-saving gas for the blue truck!:b69: |
01-15-2011, 03:42 PM | #10 |
yeah Pictures..... you might can muster up a trade!!
01-15-2011, 04:33 PM | #11 |
Can this be done to a blazer? I been looking a 2wd blazer but the ones I seen they want what I think too much $ and 4wds blazers are way cheap but I just don't like 4wds or have any use for them
Posted via Mobile Device Last edited by camaney; 01-15-2011 at 05:35 PM. |
01-15-2011, 05:22 PM | #12 |
Vintage 4x4s
Wow, around here the exchange rate is 3 2wd's for 1 4wd.
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades) 67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore ) 86 CHV K30 502 th400, apple red NEW 71 CHV K20 350 SM465, ochre (saved work truck) 71 CHV K20 292 SM465, white, tach, PTO, (future project) 72 CHV K20 350 350th, medium blue (project stocker) 01 CHV K2500hd crew, indigo blue ^3 dont run and the others don't see winter either '86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649 '71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642 '72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6 |
01-15-2011, 05:24 PM | #13 |
Wish I was closer too you, it would sure save me alot of work! As stated by others, post some pics, there's alot of guys on here besides me that want a 4wd!
Rob 72 C/10 (under reconstruction)(destruction ? LOL) 48 Willys CJ2A 1952 Super "A" Farmall (Grandfather's) |
01-15-2011, 06:58 PM | #14 |
Here was the truck when I got it
Since then I have pulled the bed and painted the frame and replaced the bed sides it just needs the body work done on the bed I have more info if you PM me |
01-15-2011, 07:21 PM | #15 |
since you have it down that far..find a 2wd longbed frame..and swap the body over...sell the 4x4 stuff on here.
01-15-2011, 09:57 PM | #16 |
I have a 2wd 3/4 roller with leafs and a D60 here in MN. I'd definitely swap rolling chassis if I was closer...damn! This condition vehicle is all you need below... I bet you can find a decent 2wd rolling chassis in a junk yard somewhere for about what you will earn selling your 4wd parts and those dished out turbines . Good luck!
1971 C-20 350/350 |
01-15-2011, 11:58 PM | #17 |
I think I am going to start looking in junk yards thanks guys. 05 its just a little road trip hahaha
01-16-2011, 04:46 PM | #18 |
I wish i was closer id take your 4x4 frame in a heart beat. I think it looked awesome originally!
1969 Chevy c20(Miss Hackjob) |
