Old 01-15-2011, 02:51 AM   #1
89chevsj
error 404
89chevsj's Avatar
invisible coolant leak
Having major problems lost about 1/4 of my coolant in 100 miles. cant find a leak, and there isnt a huge cloud of exhaust has this happened to anyone? I parked it outside to see if i could get it to drip on the snow, and absolutely nothing. any ideas. Head gasket? head? or somthin else
89 Chevy swb 350 "SJ" DD turned parts truck. SOLD
90 Chevy ext cab loooongbed. "storm trooper" Rust In Peace.
06 Kia sorento wife's car
06 charger srt8 "lucifer" my toy
'12 Kia optima
89chevsj is offline   Reply With Quote
Old 01-15-2011, 07:13 AM   #2
54 jimmy
54 jimmy's Avatar
Re: invisible coolant leak
check you heater hose quick fitting on the back passanger side of the intake they are known for cracking and leaking down the back of the block on the hot manifolds. i had the same problem on my 4.3 s15jimmy.
There is nothing you can't fix with a BFH or a FIRE WRENCH.
1997 chevy k1500 ext cab z71 (daily driver) sold
1996 chevy k1500 reg cab 4x4(daily driver)totaled
2008jeep patriot (wife's daily driver
2008 chevy 1500 ext cab 4x4 sold
2011 chevy 1500 crew cab ltz (daily driver)
1996 chevy 1500 reg cab 4x4 project sold
2006 pontiac grand prix gxp (daily work commuter)
54 jimmy is offline   Reply With Quote
Old 01-15-2011, 09:48 AM   #3
Restrorob
The One And Only !!!
Restrorob's Avatar
Also check your passenger side carpet for wetness.
93 Jeep XJ
88 Buick La Sabra
Toys;
88 TA-GTA in the works....
97 GMC Ext. Cab
Old 01-15-2011, 11:12 AM   #4
scotts62
One day...
scotts62's Avatar
Does it have a miss at all?
Scott
93 crew cab build
Project 62
Old 01-15-2011, 12:38 PM   #5
bwood
bwood's Avatar
Make sure your oil level isn't rising.
2013 Ford F150 FX4
2006 Chevy Silverado 1500
1982 Chevy C1500
2020 Ford Explorer Limited
2008 Ford Escape
bwood is offline   Reply With Quote
Old 01-15-2011, 06:31 PM   #6
89chevsj
error 404
89chevsj's Avatar
I know its not he heater core. I think i will just take it in to a garage and have them find the problem. haven't checked the rising oil level thing, praying it isn't though.
'12 Kia optima
Old 01-15-2011, 09:14 PM   #7
On my 6.5TD I had a leak in one of my thermostat crossover to head gaskets and it was like the leak 54 Jimmy suggested. The coolant would run across the intake valley and down the back of the motor & bellhousing. I never saw a drop. It all burned off or blew away while driving. I would lose a gallon in 30 miles. I thought I had a major problem and it was a cheap little gasket.
Old 01-15-2011, 09:43 PM   #8
89chevsj
error 404
89chevsj's Avatar
ok i can see that being the problem. when i bought the truck the tempp guage went all crazy and now i never see it even reach 210. I'll check on that.
'12 Kia optima
Old 01-15-2011, 11:55 PM   #9
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Cooling System Pressure Tester....find one and pump up the system. Loose hose clamps; leaking intake manifold gasket (common problem); leaking fitting for heater hose on intake (another common problem); radiator cap that won't hold pressure (bad rubber seal in the cap); all of these are common problems.
Member Nr. 2770
Old 01-16-2011, 12:08 AM   #10
89chevsj
error 404
89chevsj's Avatar
been over most havent really torn into anything much but i still need to check a few things.
'12 Kia optima
Old 01-16-2011, 12:45 AM   #11
89chevsj
error 404
89chevsj's Avatar
none whatsoever. the engine was twacked about 40k ago. so it is sound it must be somthing very simple.
twacked = heavily modded
'12 Kia optima
Old 01-16-2011, 11:42 AM   #12
scotts62
One day...
scotts62's Avatar
thats a new word i havent heard before.
Scott
93 crew cab build
Project 62
Old 01-16-2011, 09:20 PM   #13
70BLAZERX2
In your other thread you said at -20 it wont start..
I have seen this happen before..check the wires going to the coolant sensor..by t-stat.. make sure they are not green with corrosion..
.I had a 88 truck back in 90 come in for a no start..only when it was below 10 degrees...in Delaware.
It has green corroded wires..on the coolant sensor..Changed the plug..did nothing..I pulled up the pass carpet..yes antifreeze was there..but not from heater core..
But out of the Engine Computer itself..
.The wire had wicked antifreeze all the way up the harness..and filled the ECM with antifreeze...
Strange things do happen when it gets cold outside...
70BLAZERX2 is offline   Reply With Quote
Old 01-16-2011, 11:02 PM   #14
89chevsj
error 404
89chevsj's Avatar
i think its just too cold. i ran some stop leak and it hasnt dropped so i think thats ok for now. however on the other post, i havent tested but i think the block heater is unhooked or broken.
'12 Kia optima
Old 06-29-2011, 01:37 AM   #15
89chevsj
error 404
89chevsj's Avatar
ya know it is cammed but i think it shakes a bit to much but maybe it's just me, but it isn't a rhymatic shake so??? i found the heater core leaking but its still dropping coolant. not much but still. it's blowing some steam from my tail pipe. but very little. i wouldn't think it should steam at all at 65 degrees. any thoughts
'12 Kia optima
Old 06-29-2011, 01:40 AM   #16
89chevsj
error 404
89chevsj's Avatar
block heater was done. i back traced the wire it melted and was grounding out on my header.
'12 Kia optima
Old 06-29-2011, 01:43 AM   #17
89chevsj
error 404
89chevsj's Avatar
i should add, i can smell antifreeze near the front of the truck, but i havent in the exhaust.
'12 Kia optima
