Old 01-15-2011, 11:06 AM   #1
DeadheadNM
Carpe manana
DeadheadNM's Avatar
2wd front crossmember for 72 K10?
Hello:
The front crossmember on the frame of my 72 K10 is trashed from what looks like a prior towing attempt and I want to replace it. Will a 2wd 67-72 crossmember from a 1/2 or 3/4 ton truck be a direct replacement in my 4wd? I suspect it is. I searched older posts but couldn’t find an answer.
I’m stuck in the snow in Mass daydreaming about my truck back in New Mexico.
Pete
Old 01-15-2011, 06:15 PM   #2
Livrat
Member #1049
Livrat's Avatar
Re: 2wd front crossmember for 72 K10?
If you are refering to the crossmember thats riveted in directly under the radiator core support.. yes they are all the same 2WD/4WD 67-72
Livrat is offline   Reply With Quote
