Old 01-15-2011, 05:16 PM   #1
Mr. 250r
Mr. 250r's Avatar
gm 10 bolt axles
Does anyone know if the gm 10 bolt front axle will fit in a later year dana 44, i thought they couldn't because the 10 bolts were slightly larger but everytime i search it brings up which front end is better instead of sizes and stuff
Mr. 250r is offline   Reply With Quote
Old 01-15-2011, 05:56 PM   #2
Chevymaniac
Re: gm 10 bolt axles
I know that a regular dana 44 and the 10 bolt are similiar in most features and strengths. Also made was a dana 44 heavy duty. I think with this model the parts from the spindles and everything out from that point are larger than what found on the 10 bolt.
You can swap a 10 bolt in place of a dana 44.
If anyone else has more details please clime in.
Chevymaniac is offline   Reply With Quote
Old 01-23-2011, 01:50 PM   #3
rayfinseats
Look them up online and compare the part numbers from an auto parts place. If the part number is the same they will fit.
rayfinseats is offline   Reply With Quote
Old 01-23-2011, 10:12 PM   #4
orbot
orbot's Avatar
They are interchangebla from the knuckles out
http://neapco.com/n_products-catalogs.php
click on the axle cataloge you might find something also SEARCH on pirate4x4.com dont as in the chevy section...or you will get bashed.
orbot is offline   Reply With Quote
