4-link ideas
I want to 4-link my truck and looking for ideas on building my own bars and brackets, bushings etc. I'm leaning towards a triangulated 4 link set up, bag on bar. I looked at ordering a kit but nothing is reasonable and shipping is a killer, I know I can build it myself, as many others already have done the same..
my build threads '86 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415628 '67 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=635078 '63 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=674682 |
Re: 4-link ideas
I'm actually building my own wishbone link setup right now, and to be honest, I should've just bought one like the suicidedoors kit. I have the ability for sure but just the cost of buying bushings and all the metal is really not saving me a whole lot. I also ended up buying axle tabs and all the mounts too just because it was so difficult to make that many exact copies with what I had. ( cutting torch, grinder, and drill) not to mention all the time it takes to fabricate to your liking. but if you have the tools to make copies and maybe a hole drill, you should go for it. But I'll have some more progress done tomorrow on the 4 link. And I'll post up here
Max Max's bagged 81 81 rcsb bagged, 22s, build in progress 09 ext cab, 24" U2's, DD sub/amp |
![]() Join Date: Apr 2008
Re: 4-link ideas
Look here for your rod ends;
http://www.spohn.net/shop/Del-Sphere-Pivot-Joints/ I was going to use regular Heim joints but then i found these beauties
I'd rather attempt something great and fail.. than try something ordinary and succeed. Norman Vincent Peale Project: Barn Raising http://67-72chevytrucks.com/vboard/s...d.php?t=414961 Project: 30 Be Low https://67-72chevytrucks.com/vboard/...d.php?t=830583 |
Happy to be here
![]() Join Date: Mar 2000
Re: 4-link ideas
You can do it your self, but there are a lot of very reasonable priced kit out there. I would do a triangulated 4 link if it were me. You might have enough room to triangulate the bars properly on a LWB, but I would consider a wishbone instead.
Take a look in our suspension forum for a LOT of info on the topic.
Re: 4-link ideas
thanks guys, yes there are lots of reasonably priced kits out there....it's just that the shipping isn't reasonable! ....thats the only reason why I'm cosidering building my own. I don't want to pay for a kit twice.
BAD BOW-Silverado XST
Re: 4-link ideas
Add a C-4 Vette rear axel!!
Re: 4-link ideas
Doing this same thing myself but im gonna do a traditional 4-link with coilovers. There are alot of reasonable kits out there. Check out the board venders for better pricing.
A computer once beat me at chess, but it was no match for me at kick boxing. Duct tape is like the force. It has a light side, a dark side, and it holds the world together. |
#8 | |
Re: 4-link ideas
Re: 4-link ideas
I got my lower bars all tacked up today. Here's a pic. Check out my build thread to see a couple more once I get it updated in a few minutes.
![]() Posted via Mobile Device
Re: 4-link ideas
thanks. what did you use for bushings? what are you doing for upper bars wishbone or triangle?
Re: 4-link ideas
I'm doing a wishbone. I just got it tacked up today.
[IMG] ![]() Posted via Mobile Device
Happy to be here
Re: 4-link ideas
I'm not expert, but don't you need a spherical rod end on the front of your wishbone?
#13 |
Re: 4-link ideas
Im no expert either. I just built mine off of info from various kits. I don't think the spherical rod end is completely necessary. Even on the basic suicide doors wishbone kit it has the regular rod ends and bushings.
http://www.*****************/4-link-k...l-wishbone-kit Posted via Mobile Device
